Fork tube compatibility
Mr.Mow
4 years ago
So.. are tubes tubes? I have a set of 49mm tubes from my 2015 dyna, I’m wanting to go 2-4+ on my M8 lowrider (also 49mm and these tubes will be 3-4+ exactly), anyone know if they’ll drop in? Or are tubes really specific to different forks?
4 years ago
You will have to research this one as no they are not all interchangeable. Different thread and shapes for the tops and internals etc.
Looking to swap out my Sporty stock tubes for a +2 to +4 as well!
Im looking at a proper kit from the States as some setups I have seen online are really sketchey. And do NOT try those screw on 2" extensions as I have not heard a single good thing about them.
