Online: softfat
Starter motor troubles
  • Floyd
    Floyd
    4 years ago
    Solenoid throws pinion in, engages with ring gear ...starter motor is spinning but not engaging pinion shaft....
    Thinking cranking power gone in battery, but battery test (2 yr old battery) says all fine...
    Any ideas? Uploading video....
  • gidgi
    gidgi
    4 years ago
    sounds like starter clutch needs replacing usually an easy fix ,just done mine under a couple hundred
  • Floyd
    Floyd
    4 years ago
    Quoting gidgi on 17 Oct 2021 05:13 AM
    Thanks gidgi, from the manual it looks like the clutch shaft and springs may be the trouble, i will investigate....
  • Kato
    Kato
    4 years ago
    i had the same "sound" as yours (exactly)
    and the starter was spinning just like yours ............needed new starter motor to fix mine
    Does that assist
  • Floyd
    Floyd
    4 years ago
    Thanks Kato yes helpful, I have my starter in pieces and can see no broken or worn parts ?? Thanks for the help. Really want to know what has caused this trouble before I order a new starter motor. Thinking that it is just the starter motor clutch in the housing.
    Can anyone tell me what I would see if the clutch assembly was faulty, the bearings look fine.
  • Chrisso63
    Chrisso63
    4 years ago
    Definitely your starter clutch.. I've fixed allot of them, the starter clutch is a 1 way bearing while you have it apart if your starter clutch is rooted you will be able to spin it either way.. New one from easyR is about $60-$80 I think from memory..
