breakout final drive pulley swap
bodgie1307
4 years ago
Has anyone done the 30/70 tooth belt pulley swap on a softail breakout ? ive done it and used a dakota digital Speedo calibration module to calibrate speedo because i dont have a Power vision to modify the VSS value.
speedo works but the gear indicator does no display correct gear.
For those that have done the swap and used a power vision to mod the VSS value does your shift indicator work as it should ??
Thanks
Bodgie
