Online: B0nes, FONTANA302
Footrest
  • FBUser278
    FBUser278
    4 years ago
    Have a 2017 cvo streetglide with these pegs on,looking to get hwy pegs ,my problem is I can’t the brand of these pegs ,Anybody know the name of these pegs
  • Daffy
    Daffy
    4 years ago
    They look like Kuryakyn. You’ll be able to get some thing similar from them. Try Easyr Very helpful folks. Cheers
  • steelo
    steelo
    4 years ago
    Close. They are Harley "Airflow".
    May I recommend these Harley Highway peg mounts. Black or Chrome. Look good, Nicely made, fit well with CVO lowers, very adjustable to find sweet spot.
    Save your money and just get standard long pegs to fit highway mounts. They fold nicely out of the way and are unobtrusive.
  • Daffy
    Daffy
    4 years ago
    Those mounts look great. I already had kuryakyn so I went with them. Otherwise would have gotten these.
  • Soapbox2627
    Soapbox2627
    4 years ago
    Quoting steelo on 30 Aug 2021 01:08 AMedited: 30 Aug 2021 02:49 AM
    I have a set of these on my Roadglide, I could have got away with the 2" set but now I have another option to lay my heals across them and stretch out a little more
    they are a solid set, the trick (I found) is to get them square then set them up-down for length, and don't do them up until you are satisfied, they do show if you move them
  • Daffy
    Daffy
    4 years ago
    What size is the slot where the pegs go?Just wondering if my Kuryakyn pegs will fit.
  • Soapbox2627
    Soapbox2627
    4 years ago
    mine are tight but not tight enough to stay up, I have the spring thing in there but will put a washer in the other side to take up the room, I feel I will start to warp/squeeze the gap to much if I tighten it up more
  • steelo
    steelo
    4 years ago
    They look good mr S. Glad you home safe and well.
    Daffy. All Harley and oem pegs should fit. Otherwise what would be the point.
