Online: Merv
Super Start Battery - not so super at all
  • Wideglider
    Wideglider
    4 years ago
    Yes I know, another battery thread.
    Wow, a Super Start Battery (SSB) they said.
    I had always had bought the genuine HD branded battery - usually lasted around 5 years,.
    Unfortunately I listened to the hype (greater Cold Cranking Amps ets) and other claimed advantages of the 'SSB', bought one - well, it lasted only 11 months.
    Cared for both batteries in the same manner by using charger to maintain.
    Bought the HD battery today, confident I'll get 5 years again. When you're on to a good thing, stick to it!
    4 years ago
    Quoting Wideglider on 26 Jul 2021 09:17 AM
    Hey Wideglider , go get a replacement as 12 month  or they replace after they test.   But the do crank harder as the genuine HD( not made by Harley just has there name) has 370cca & could not turn over my little 88” sporty sounded like battery was having a hernia! So out. With genuine & in with SSB hit the button & it spun motor over easy ( for a few months then got a bit weaker ) .
    Anyway a few years and a few more SSB latter. I went got a real Aussie Yuasa have not needed to keep it plugged into battery tender & she fire’s up Quick so Yuasa me go get one. They also make Yuasa in USA but Battery World stock the Aussie made Yuasa 2 year guarantee , I asked if index to charge beforeuseing , guy said no & it has not been on a charger yet but fires up quick every time. Touchwood
  • Grease Monkey
    Grease Monkey
    4 years ago
    I don't get 5 years from HD batteries, used to, my first one went 7 years before it through the towel in without ever seeing a charger, road bike most days, all the ones I've had since have seen at least partial tender top ups but 1.5 - 2 years seems to be it, must be doing something wrong?
  • leachy
    leachy
    4 years ago
    I feel that the Yuasa batteries are the best but expensive. My Honda VFR 2008 model came with one and I only replaced it last year because I was heading to Phillip Island, and thought this thing cant last forever, (12 years). My Suzuki DR has an SSB and that thing has been flogged, its now 8 years old been flat a couple of times and it still starts the DR with a hi comp piston. My Harley battery is on a HD charger and its original and 5 years old, starts the bike easily, the other are just $25.00 trickle chargers from Jaycar. I occasionally take them out of the bike and hook them up to my Projecta battery charger and put them through a rejuvenation cycle. I figure for the inconvenience its saves me a bit of money in the long run and its really annoying putting all the gear on and hitting the button and nothing happening.
    Regards
    Leachy
  • Wideglider
    Wideglider
    4 years ago
    Quoting Krash Kinkade on 27 Jul 2021 04:34 AM
    Found my receipt (mentions 12 months warranty), the Indy shop also had engraved the top of the battery with the purchase date.
    Like I said, maintained the battery in same manner as all others - that's my argument tomorrow.
  • Grease Monkey
    Grease Monkey
    4 years ago
    Warranty is warranty after all, they will probably try and give you another battery though, take them the good fight, hope it goes in your favour.
    4 years ago
    I don't know about the different places that sell the SSB new, but the Factory in Sydney will always replace a bad one that's less than a year old.
    Off the subject of SSB but still on Batteries. the Harley Motor's are big & take a bit out of the small size battery, every time we start them. so have to expect the battery won't last  like a bike with a smaller motor & less cranking pressure to start.
  • STEAMER
    STEAMER
    4 years ago
    Quoting Krash Kinkade on 29 Jul 2021 03:41 AM
    Batteries Direct at Peakhurst, where i bought my SSB,    great battety.
