Online: obisteve
S&S adjustable pushrods question
  • Adam76
    Adam76
    4 years ago
    Hey guys,
    Anyone used these adj PRs with the stock oem pushrod tubes?
    I read about the adj PRs being fatter and rubbing on the stock PR cover tubes?
    Is there any way of getting around this problem other than chucking them on a lathe and boring out the tops of the tubes? I don't have access to a lathe.
    Bike is '02 softail
  • Adam76
    Adam76
    4 years ago
    Sorry,
    Std adjustables (not the EZ install or quickies).
    2002 TC 88 Softail with 96" later model heads.
    Or perhaps these would work.... looks like the adjuster nuts are right down the bottom of the rods.
  • Adam76
    Adam76
    4 years ago
    Thanks Magnum,
    Good info. I might have to look into machining the tops of my tubes if I can find someone who knows how to do it...
    I just can't work out why the aftermarket tubes are so expensive. Otherwise I'd haves just bought a set already.
  • Grease Monkey
    Grease Monkey
    4 years ago
    Sharp 5/8 drill bit and a steady hand will do it, one of mine rubs and because of the rocker lockers I can't push the support plate across a little to alleviate it, on the list of one day jobs.
