Online:
obisteve
Fuel filter fsxb breakout
bodgie1307
4 years ago
Hi
Does the regulator/filter assy need to be completely removed from tank to replace fuel filter on 14 breakout. Manual is vague re filter replacement.
Thanks
Bodgie
bodgie1307
4 years ago
Thanks mate .
So you couldn't just remove the top plate from the reg assy which is held in place on top plate with spring clamp. Leave lines connected and then remove clip holding filter housing to reg and replace filter.
When I upgraded to CVO tank console I had to swap out top plate so I disconnected wires and vent line then unclipped reg assy from plate then just clipped reg back onto new top plate. Just can't recall if you can remove filter housing with reg in situ once plate removed.
Any special tools required to release fuel lines from regulator assy.
bodgie1307
4 years ago
The bikes only done 27k the service schedule says replace 160k but when I replaced my car filter at 30k it was filthy.
