Online: obisteve
dyno results
  • Brad24
    Brad24
    4 years ago
    Got the Bob tuned after fitting a supertrapp 2 into 1 from a V&H big radius & changed out the SE260 cam to a T-man 625
    The bike has a early SE stage 4 kit with the 110+ heads
    Work done by Thundertech in WA
    Happy Brad
  • Grease Monkey
    Grease Monkey
    4 years ago
    A decent pipe and a good tune make for a big smile, congrats
  • Jay-Dee
    Jay-Dee
    4 years ago
    18hp and 12lbs/ft with that nice flat torque curve is a great gain, that's a cracker, you'll really feel that. Those T Man cams use short lobe centres with good lift and duration and give pretty decent results from what I've seen.
  • Brad24
    Brad24
    4 years ago
    Quoting Grease Monkey on 15 Jul 2021 10:46 AM
  • Brad24
    Brad24
    4 years ago
    Quoting Jay-Dee on 15 Jul 2021 11:51 AM
    It seems a whole lot better, it was 13 degrees in Perth yesterday with wet roads on the way home. Keen for a nice day to get up it a little
  • Lushy
    Lushy
    4 years ago
    Brand is a good guy, he would love doing that job, half his gains would be f---ing off the  Big radius pipes. Nice one.
  • Jay-Dee
    Jay-Dee
    4 years ago
    And it probably sounds a whole lot better which is an extra bonus.
  • Brad24
    Brad24
    4 years ago
    Quoting Jay-Dee on 16 Jul 2021 12:34 AM
    The sound is not as loud but it’s a lot deeper if that makes sense
    I like it a lot more than I thought I would
    4 years ago
    Good improvement and you can sell the old parts to recoup some $. Bet it rides better at partial throttle and has more throttle response in street riding conditions too.
    Who recommended the supermeg exhaust and the Tman 625 cam to you?
  • Brad24
    Brad24
    4 years ago
    Quoting fatbat on 16 Jul 2021 10:40 PMedited: 16 Jul 2021 10:42 PM
    Yeah it’s way better to ride. I’ve already sold the V&H pipes.
    Thundertech recommended the supertrapp pipe but I went with the fat shot rather than the supermeg purely because I preferred the look. I wasn’t sure I’d like the sound it makes but I do.
    It’s definitely a deeper sound at idle
    For the cam I did a bunch of reading on the US forums about what works with the early SE 110+ heads
    A few blokes with the same combination had run the T-man 625 cam with very similar results
    It’s around 19 degrees smaller than the SE260
    4 years ago
    Quoting Brad24 on 18 Jul 2021 12:08 AM
    how many ST disc's are you using at end of muffler?
    4 years ago
    Thanks! Missed that. I’ve used Supertrapp on a TC 95”, I liked them, but , at that time I was drag racing in SE Harley’s ( the series finished & folded up ) . While competing in that & riding home from track, I had the guts fall out of the. Muffler. So took the ST pipe off , put a set of old cycle shack duels with baffles removed on. Went to the track & ran three tenths quicker & 12mph faster trap speed. So I just have stuck with the cycle shack ( stock looking pipe ) since, but I run baffles now.
    But the ST a good system as you can tune it. But you have to re pack them & need closed end Capp  to get noise level down.then add more disc’s. I tried them all different ways but they still could not beat the old Cycle Shacks ( baffle removed ) that’s at the track street class ( same as racing off the lights on street ( but legal)
