Clutch hub mainshaft nut removal help needed
  • Adam76
    Adam76
    4 years ago
    Hey guys.
    I'm following the service manual to remove primary chain and clutch assembly as a whole  - so I can get the inner primary off to change the rear belt. 2002 Softail.
    Now the bike is in gear, but the clutch basket and rear sprocket spins freely and therefore the mainshaft nut can't be loosened?? I don't have the rear wheel on to lock the brake.
    How do I lock up the rear drive sprocket so I can undo the clutch hub main shaft nut?
    I have the primary chain locking tool in place, but that makes zero difference. When I try and loosen the sprocket nut the whole assembly just spins? I thought the trans being in 5 th gear would not allow this... Now I'm stuck.
    Any advice appreciated.
  • Old Fatty
    Old Fatty
    4 years ago
    Quoting Adam76 on 06 Jul 2021 03:44 AMedited: 06 Jul 2021 05:46 AM
    Hey guys.
    I've put it in 5th gear and used a C clamp on the rear brake pedal to lock the brake on.
  • Adam76
    Adam76
    4 years ago
    Hey guys.
    Quoting Old Fatty on 06 Jul 2021 05:16 AM
    Thanks fatty, but my complete rear end is off,  including the swingarm. So I can't apply the brake to hold the drive sprocket from spinning so I can remove the clutch mainshaft nut.
  • beaglebasher
    beaglebasher
    4 years ago
    Try first gear
    4 years ago
    A rattle gun ( electric or air ) can do the job . but they don't always recommend . ( still it works. )
  • Adam76
    Adam76
    4 years ago
    Quoting Krash Kinkade on 06 Jul 2021 06:27 AM
    Thanks Krash, it's that or put the swingarm, rear wheel, brake and belt sprocket back on, right?
    Even with the impact wrench, what do I use to hold the rear drive sprocket from turning?
    4 years ago
    Quoting Adam76 on 06 Jul 2021 07:30 AMedited: 06 Jul 2021 07:31 AM
    just remember it's left hand thread.
  • Adam76
    Adam76
    4 years ago
    Yeah, thanks... I know it's left hand thread,  it's just that there's got to be an easier way?
    Looks like I'm going to have to put the swingarm and rear wheel back on just to get the inner primary off. Who would have thought changing a drive belt would be this hard.
  • binnsy
    binnsy
    4 years ago
    Quoting Adam76 on 06 Jul 2021 12:28 PM
    Would have thought the initial impact from an impact gun/rattle gun would break the seal on the nut with the sheer shock of the impact.  Yes the rear drive sprocket will turn as well, but the impact should rattle the other nut loose first. albeit a split second earlier.  works on engine flywheels etc.  Cant see why it wouldn't work here?
    4 years ago
    Hint... Is there a reason you removed the clutch plates ?
  • Adam76
    Adam76
    4 years ago
    Quoting speedzter on 06 Jul 2021 11:39 PM
    Hey speedzter,
    The impact gun method worked. 👍
  • Adam76
    Adam76
    4 years ago
    Got it
  • Adam76
    Adam76
    4 years ago
    Quoting binnsy on 06 Jul 2021 11:09 PM
    Thanks binnsy,
    The impact gun worked like a charm.
    Cheers for the help fellas. 👍👍
  • binnsy
    binnsy
    4 years ago
    Quoting Adam76 on 07 Jul 2021 02:53 AM
    Thanks binnsy,
    Great news mate, glad it worked.
