Rotor Thickness
  • TJU
    TJU
    4 years ago
    Gidday all .. just checking to see if anyone knew if there was a different thickness between Front and Rear rotors .
    Looking at selling my Original 99 Springer front and rear wheels , with rotors and pulley attached .. when giving them a bit of a clean up i noticed a different thickness recommendation stamped on the disk from front to rear .
    As i have both rotors removed from wheels i wanted to make sure i put the right rotor on the correct wheel for the guy who might be buying them .
    Any ideas please .
  • John.R
    John.R
    4 years ago
    Rears are usually thicker but if you check PN against Google it should confirm.
  • beaglebasher
    beaglebasher
    4 years ago
    I have no idea if the front and rear rotors are a different width but I would have thought the opposite from John.
    Wouldnt the front disc be thicker?  I have a micrometer in the shed so I will measure them and report back.
  • TJU
    TJU
    4 years ago
    Thanks guys .. appreciate the reply`s .. will do a google search and see if anything comes up .. of course i can go to dealer at some point but just wanted to check here first .
    Cheers .
