Online:
Merv
Misguided Boombox GTS
wobble
4 years ago
Hi there I’m hoping someone might be able to help, I have a 2019 ultra limited, the navigation is directing me up wrong roads, I have had the latest update done and it is still miss directing me, any help would be appreciated, cheers Wobble
dicko
4 years ago
Dunno about the ultra, but my navman has different routing like Easiest, fastest ,most economical etc. I normally use easiest unless I know the shortcut, the others often take you up a back road which may have been closed, and not updated. maybe that???
wobble likes this post
DocGreen
4 years ago
Wobble, you most likely have selected stuff like avoid toll roads etc. If you've got the boom box manual, have read through that. If you don't have one, I believe you can download an electronic version straight from HD.
Think the site is Harley
Davidson.com
and select the my bike tab, log in or enter your vin and should be able to find it from there.
Doc
wobble
4 years ago
Thanks Doc, I have the manual and have read it, several times, I think my grey hair and lack of tech ability cause poor understanding, I am doing something wrong and as I’m 2 hours ride to my dealer it’s difficult to remedy. Thanks Wobble
