Online: Merv
lithium batteries yes or nope ?
  • brucecul
    brucecul
    4 years ago
    so what is the story with fitting a lithium battery to a dyna , any dramas ?
    4 years ago
    they have a few positives , but I'm not sure how they will be long term.
  • Wideglider
    Wideglider
    4 years ago
    Quoting Krash Kinkade on 17 May 2021 10:33 AM
    They do have a positive, but don't forget there is a negative side to these lithium batteries as well.
  • steelo
    steelo
    4 years ago
    In what capacity wg?
  • brucecul
    brucecul
    4 years ago
    longevity , charging a different style of battery . if anyone has had a negative or positive
  • steelo
    steelo
    4 years ago
    I think if you need a battery, want to try something new and can afford it. Get one. Be the first on this forum and review it after 12 months.
    Normal Battery i’ve had for only a couple years is showing signs of slowing up despite regular riding and trickle charging.
  • Soapbox2627
    Soapbox2627
    4 years ago
    We are half way towards a lithium battery
    The wife’s trickle charger does both lead acid or lithium
  • DocGreen
    DocGreen
    4 years ago
    Recently had to replace my 4yr old battery and was toying with the idea of going lithium, but can't understand how we're told you need a special charger to maintain them, yet you put it your bike with the original charging system?
    What am I missing here?  Went for an AGM again for $170 delivered.
    Doc
  • FBUser42
    FBUser42
    4 years ago
    Watch the ricks video..basically you need.a lower output regulator. Only about .5 volts just so u dont boil the lithium. Them AA batteries inside cook easy.. If u think im loopie look in u you tube tesla battery.... But. Understand the fire safety risk with theese batteries they reignite [fire]  hard too put out. so check your insurance policy hhaa
