Online:
Neale
Wiring confusion, 1946 flathead
Aaron
4 years ago
Hi all, have 1946 flathead engine, trying to work out wiring, have most of it done. Confused about charging system, generator has two wires, going to rectifier? Under seat, no other wires coming from this. I believe at least one should go to the battery, for charging? This part, rectifier? Is rubber mounted, to isolate it from the frame. Think I need an expert. Thank you for looking, and any help you can provide. Cheers, Aaron
Bangkokbob
4 years ago
Hi there.
I'm no expert but it sounds like you don't have the correct parts on the bike.
Take pics of generator and regulator and that will help to answer questions.
Regards,
B.B.
steelo likes this post
