Online:
bikenut57, Hilly, Wanderer57
Might be of use to someone (Adapter)
binnsy
4 years ago
I have the standard battery tender connection on my SG to suit the HD battery tenders. I use a CTEK multi stage charger for maintenance charging my bikes. The connections are different for these two chargers so weren't compatible. Didn't want to ditch the CTEK as they are an expensive unit and very good with the multi stage process.
I located an adapter on line at a place called Edisons (could no doubt buy them elsewhere I imagine) for about 40 bucks. This allows me to use my CTEK on the bike. Thought somebody else may have the same issue and looking for a fix so took some pics for info. Seems to work very well and had an inbuilt charge indicator, not that its needed as the CTEK has one anyway. Saved me wasting the charger I have and having to give HD some more cash. I could have disconnected the HD one if I wanted but it was fitted when the bike was new an is well and truly wrapped up with all the other wiring. Pics attached of the set up now if it helps someone.
paulybronco likes this post
4 years ago
Cheers Binnsy i also have the same charger, great bit of gear. Will look at that adaptor
binnsy
4 years ago
Quoting paulybronco on 27 Apr 2021 02:22 AM
Here ya go
https://www.edisons.com.au/ctek-comfort-indicator-pigtail-battery-charger-pig-tail-accessory-cable-56-564/
