Online: Neale
wider rear end
  • FXSTC
    FXSTC
    4 years ago
    Hey is it possible to get the rear end of a 2013 softail widened from 200 to 240 or even 300?
  • tylerronan
    tylerronan
    4 years ago
    Anything is possible. Have you ridden a breakout? If not do that first. Might be cheaper just buying one if thats the look your after. If not a heartland or similar conversion kit will do.
  • Birtyyy
    Birtyyy
    4 years ago
    Of course it's possible. Expensive, but possible. You aren't just looking at wider rim and tyre, you'll be up for a new swingarm as well as spacing the drive out on your gearbox among other things.
  • beaglebasher
    beaglebasher
    4 years ago
    Quoting FXSTC on 26 Apr 2021 06:29 AM
    Why would you want to do that FXSTC?
    It is a subjective thing I suppose but why not go for a really fat back tyre?
    Like 350 mm or 500 mm?
    Personally I reckon 180 is perfect. The tyre on my bike is only 150 but I have learned to live with it.
