Online: bikenut57, Hilly, Wanderer57
  • binnsy
    binnsy
    4 years ago
    Sundowner seat to suit Street Glide Special,2018 model Higher sissy bar, have one but its pretty low, 10 inch windsplitter.  Light smoke preferably.
    Thought I would try on here before ordering all new ones.
  • keith
    keith
    4 years ago
    As I said in the PM two of them, the other is a 5" ok around town, cop the buffering on the open road.Cheers Keith
  • binnsy
    binnsy
    4 years ago
    Quoting keith on 27 Apr 2021 06:05 AM
    Looks pretty good mate. Think it will be a case of trial and error re size wise.  How much do you want for it ? And would you post it to Victoria 3220.
  • keith
    keith
    4 years ago
    PM sent mate. I have a tinted clock works 8" that works for me.
  • binnsy
    binnsy
    4 years ago
    Thanks to Keith from the forum I now have the ten inch screen fitted to the bike. Will test ride if it stops pissing down here any time soon. About 4 inches in the old scale higher than the one that was on it. Looks nice on the bike. Terrible photos from inside the garage but you get the drift.
    I like it.
    Thanks again Keith.
  • steelo
    steelo
    4 years ago
    I think you’ll be happy with that young Binnsy. Same as one I use. Do remember that no screen is going to give you complete protection. Vent open.
  • binnsy
    binnsy
    4 years ago
    Quoting steelo on 04 May 2021 06:44 AM
    Thanks steelo.  Yes I ride with vent open. Learnt that with the windsplitter on the fatty.  Thought it was the same as yours.  Will be good I believe.  Keep me out of the wind on the way to the Floriade.
