Online: Merv
cam recommendation
  • Brad24
    Brad24
    4 years ago
    G'day
    Ive got a 2010 Fat Bob with on of the early SE stage 4 kits on it
    Screamin’ Eagle® Performance 110+ Heads - 2.120" diameter intake valves (has ACR)
    high-compression forged aluminum 10.5:1 pistons matched to the 110+ heads
    103 kit
    SE260 cam
    Perfect-Fit Pushrods
    58mm EFI throttle body
    high flow injectors
    3-7/8" diameter highlighted cylinders
    Super Tuner
    SD Heavy Breather A/I
    V&H big radius pipes
    Im told it made 109HP & 100 torque
    I see the later stage 4 kits have the 259E cams & different heads
    Are the 259E cams a better fit?
    Ive got a Supertrapp big shot 2 into 1 pipe Im going to fit & get the bike dyno tuned
    The SE260 cam has a fairly high duration number & from what Ive learned in the HiPo car game sometimes less cam is more
    Any suggestions on a cam that would be a better fit?
    Power & especially torque numbers seem to be a little down from what Ive read
    4 years ago
    Depends on what you want but at 10.5 the s&s 585 is consistently strong.
  • Brad24
    Brad24
    4 years ago
    Thanks mate, PM sent
  • Brad24
    Brad24
    4 years ago
    Quoting fatbat on 22 Apr 2021 08:11 PM
    thanks mate
  • Adam76
    Adam76
    4 years ago
    I agree the exhaust plays a big role. What would you suggest Mark? Does it have to be a 2 -1 or are there some decent 2- 2 pipes out  there?
    Thanks
