Online: bikenut57, Hilly, Wanderer57
Upgrade For 37707-84A Clutch Basket
  • Longjohn
    Longjohn
    4 years ago
    Hi All
    I hope someone can help me with some information?
    My bike is an 1986 FXWG solid mounted EVO engine running a Baker 6 into 4 transmission with the tapered main shaft and key. clutch is a Rivera Primo 7 plate Part # 1056-0003. i am currently in the process of building a hot S&S 113 with Mikuni carb and head works it should make 120+ HP.
    I'm thinking the week spot will end up being the stock Harley Clutch Basket/shell Part # 37707-84A and or the taper and keyway.
    my two questions are:
    Is there Aftermarket clutch baskets that directly replace the Harley Clutch Basket/shell Part # 37707-84A?
    Can i replace the main shaft in my baker trans and go to a spline to replace the Taper and keyway?
    I have emailed Baker and several aftermarket suppliers and still waiting for responses.
    any assistance would be greatly appreciated
