Online: John.R, speedzter
Bottom end rebuild? Advice needed
  • Adam76
    Adam76
    4 years ago
    Hey guys,
    The new project '02 fatboy arrived a few days ago from interstate...  turns out to be way more of a project than I was told and basically the bike is a basket case piece of shiit that barely runs.
    Was just planning on a top end rebuild from 88 - 95" but this motor feels like it's done 200,000 kms and probably has as the scumbag who sold it to me didn't tell me the Speedo didn't work. Stuck on 46K and the needle doesn't move.
    I have a new Speedo sensor on the way to fix that hopefully.
    Anyways, my question is, how do you know when a bottom end rebuild is a good idea, and if so what's involved?
    Thanks.
  • John.R
    John.R
    4 years ago
    Check run out and go from there.
  • Adam76
    Adam76
    4 years ago
    Quoting John.R on 27 Mar 2021 12:32 AM
    Thanks, if run out is bad... who  does crank work here? Don't want to have to buy an S&S crank for 2.5K $$$
    4 years ago
    Top end is one thing. Bottom end is another world in terms of who can do the work and all the labour. A whole new engine should also be considered IF the bottom end needs attention. Like an s&s 111
  • Adam76
    Adam76
    4 years ago
    Quoting fatbat on 27 Mar 2021 06:24 AM
    Yeah thanks, that did cross my mind for about a whole 3 seconds  πŸ˜‚  no way I can spring for an S&S complete motor and all necessary hardware to finish. $10K
    I was just looking at a crank rebalance / rebuild / repair and thought that there might be a shop in Australia that does this sort of stuff? I have no idea on what it would cost or what's involved, just considering my options.
  • Nath103
    Nath103
    4 years ago
    Quoting Adam76 on 29 Mar 2021 01:02 AM
    Where are you located?
    Second hand motor from a wrecked bike?
  • Soapbox2627
    Soapbox2627
    4 years ago
    I done a cam bearing on my '04 88cu nightrain, in may 2013, this was the quote to fix and upgrade
    FXSTB engine repair options
    88cui 60hp with 80ftlbs approx
    Complete engine gasket kit  17053-99C  $131.05 in stock
    SE upgraded cam support plate with oil pump  25284-11 $630.40  ins tock
    Pistons and rings 21930-99   $123.40 each  Backorder 2- 3 week s
    Crank shaft 23971-03B $1219.30  backorder 2 -3  weeks
    All bearings 24605-07 $38.95  in stock
    Camshaft front 25534-99 $168.90 backorder 2 – 3 weeks
    Camshaft rear  25544-00 $168.90 backorder 2 – 3 weeks
    Cam service kit 17045-99D $138.65  in stock
    Parts total $2742.95
    Oils/Sundries $50
    Labour $2376
    Grand total $5168.95
    Or you can go this much better option!
    103cui with 204 cams 80hp with 100ftlbs approx
    Screamin Eagle piston kit 103 22144-08B   $378.20
    Crank shaft $1575.10  backorder 2 -3  weeks
    Screamin Eagle 204 cams 25464-06  $416.05
    Parts total $3308.40
    Boring cylinders $240
    Oils/Sundries $50
    Labour $2376
    Grand total $5974.44
    this bike can loosen the rear wheel into 3rd gear
    I know it's old but I was told I could just upgrade the motor cheaper, (this forum) I rebuilt prior to this advice
  • Adam76
    Adam76
    4 years ago
    Quoting Soapbox2627 on 31 Mar 2021 07:14 AM
    Oils/Sundries $50
    Labour $2376
    Oils/Sundries $50
    Labour $2376
    Thanks, that's good info.
    Correct me if I'm wrong, but in the second option you say 103". I know this is possible with the crank, but how far can the stock tc88 cylinders be bored to? I thought 3.937" was absolute max.  Or, does that that equal 103" once the crank  is changed?
  • Soapbox2627
    Soapbox2627
    4 years ago
    my understanding is the 103 had a different stroke length so the crank needed changing, they used my cylinders so must have been bored out, was great, still looks standard but went like stink, surprised a lot of bigger bikes
  • John.R
    John.R
    4 years ago
    Oils/Sundries $50
    Labour $2376
    Oils/Sundries $50
    Labour $2376
    Quoting Adam76 on 01 Apr 2021 01:38 AM
    Interestingly enough, I've got a brand new take out set of 103 cylinders in the garage, they are the exact same size as 95in pistons, I.e 3.875 (from memory)
    88 and 96in cylinders are the same bore.
  • Adam76
    Adam76
    4 years ago
    Oils/Sundries $50
    Labour $2376
    Oils/Sundries $50
    Labour $2376
    Quoting John.R on 01 Apr 2021 02:54 AM
    So, to build a 103 stroker out of an 88 motor you would also need the take off 103 cylinders right? The longer stroke wouldn't work with the stock 88 / 96 cylinders..  have I got that right?
    4 years ago
    The 88 cylinders and pistons are the same as the 96 but the 96 has the longer stroke.
    The 95 cylinders and pistons are the same as the 103 but the 103 has the longer stroke.
    88 and 95 have the same stroke with different bore cylinders. Just like 96 and 103 have the same stroke with different bore cylinders.
    If you’re going to the trouble of repairing or replacing the bottom end, go as big as possible (within budget) in both stroke and bore
  • John.R
    John.R
    4 years ago
    If I was building from scratch I'd be aiming for a square motor myself, bore and stroke the same dimensions.
  • Wideglider
    Wideglider
    4 years ago
    Quoting John.R on 02 Apr 2021 03:55 AMedited: 02 Apr 2021 03:55 AM
    What are the advantages of a square motor?
  • John.R
    John.R
    4 years ago
    Balanced between power and reliability and you rev them.
    Big stroker motors have the piston moving much faster for a given RPM.
    4 years ago
    Quoting Wideglider on 02 Apr 2021 06:07 AM
    Good compromise between your small stroke engine that loves revs and your long stroke engine which typically revs lower but has lots of torque down low
  • Adam76
    Adam76
    4 years ago
    Is that possible without having to bore the cases to fit bigger cylinders?
    I'm thinking it must be because S&S did a drop on 100" kit for tc88s that had a 4.000" bore with the stock 4.000" stroke. I think there are a few left in stock at some places but not being produced by S&S anymore due to to many cases of fractured cylinder spigots?
    Then again, just boring the stock cylinders to 98" gets you pretty close to 100" anyways for much less $$$.
  • Adam76
    Adam76
    4 years ago
    Quoting fatbat on 02 Apr 2021 08:33 AMedited: 02 Apr 2021 08:34 AM
    Yep, good point. Low end Tq and fast spinning motor πŸ‘
  • milo1
    milo1
    4 years ago
    My advice you need to plan. $ how much can you stretch too. Are you doing the work that will halve the price. Or some of the work pro rata. Leak back tests, compression tests. Oil pressure. these will determine a lot. If the head comes off then crank can be assessed. With bigger bores and cams etc you should be able to get a lot of power out of your bike. As said you can get near 100cube boring out your 88. I f you want a square motor you are as close to 4 x4 as you can get!
    My two bobs worth if it runs get the above tested if good then save your pennies and ride. If it needs a top end then get a decent rebore piston etc head tidy, cam and you will be having fun for years. My friend got his 88 - 95 with cam etc for $3K.
    As said crank can be assessed when barrels come off.
    If crank is in need of rebuild, harley cranks can go huge mileage if oil is kept up to the knocker, then you have an big decision. Getting the crank rebuilt you wouldn't bother you would get a longer stroke one get it balanced, welded and trued. You would also get it bored out maybe 114 this size will still give longevity. Why would you not get a timken. Gear cams and upgraded oil pump. Oh yeah oil cooler. Clutch. That 111 s and s is not that dear with warranty!
    Last word dont fixate on the crank, if it is f---- then rest of bike might be too.
    Remember there are other crate motors and yes s and s is one of the best. Ultima can offer a good alternative yeah everyone knocks them. Only have a limited experience with them but has been favourable.
    4 years ago
    I  like the 88" stroke with barrels bored to 95" , they rev smooth. but depends what your planing to use the bike for?
