Online:
Hilly
114 M8 stage 2 S&S cam upgrade question.
Tags
4 years ago
Hi all, I am new to HD Forums and there probably is a ton of info on this already. I have a 11/2018 streetglide special 114 M8 , I already have stage 1 with SE pod filter V & H slip ons & FP3 tuner, I want to install a torque cam & thinking of going with the S & S 475 cam, I don't know if I need to go with the complete cam chest setup or can I just go with the cam, adj pushrods,and tappets, I have also been told if I went with the 2nd option it's a good idea to install the latest HD oil pump. I won't be going any further than stage 2 so I don't know if I need to go with the complete cam chest or the cheaper option, any help much appreciated and the best place to buy the above parts. Cheers.
WideglidingNZ
4 years ago
Good choice as for a cam (S&S 475) i went for the SE power cam on my lowrider just to keep the warranty, i would do the my20 oil pump(2020 model), adjustable pushrods and they also replaced a cam bearing from memory, the dealer never mentioned anything about the tappets though? you will be pleased with the improvement a cam makes for these M-8's
