Online: Retroman
2019 Slim Throttle problem
  • Mesmer
    Mesmer
    4 years ago
    Hi there guys, my partner has a 2019 Slim. All was good with it until we had a Heavy Breather fitted (with tune). Rode fine on the way home, started her up again this morning and the revs are hanging at 2500-3000! Give the throttle a blip and the revs goe down slowly to 1050ish.
    I'm thinking either an air leak or a problem with the tune?
    Any thoughts would be appreciated.
  • Mesmer
    Mesmer
    3 years ago
    Update: problem was air leaks caused by twisted seals further in. This probably occurred at the factory. new seals properly installed, problem solved.
  • evo94
    evo94
    3 years ago
    hopefully it hasnt taken this long to fix ....:)
  • Grease Monkey
    Grease Monkey
    3 years ago
    Usually manifold leaks are created when the backing plate is removed or replaced to fit a different air cleaner and not enough care is taken to not put pressure on the seals during reassembly, not saying that's what it was in this case just that it does happen, often.
  • Lushy
    Lushy
    3 years ago
    Manifold leaks can also occur because of the poxy plastic design. I have had six customers let down now. Had one go on the dyno with 57kms on the Speedo. Buy an alloy manifold to solve the issue long term.
  • robots
    robots
    3 years ago
    Yeah just follow manual
    Very simple, backing plate has to be on prior to doing up manifold clamps, use Vaseline
    No need for video
  • Grease Monkey
    Grease Monkey
    3 years ago
    Quoting Lushy on 22 May 2022 09:56 PM
    Isn't that a shit design! Be the first thing I'd piss off on an M8
  • Baloffski
    Baloffski
    3 years ago
    Plastic can be a really usefull product but any way can avoid utilising it I'll go something else, the shitty stuff. Vaselin or vass,  petroleum jelly is good shit to have on hand. Always got a tube of KY or jar of vass in tool box. Mesmer good stuff ya sorted.
    Thanks for tips blokes.
  • steelo
    steelo
    3 years ago
    Quoting Baloffski on 23 May 2022 11:14 AM
    Rich girl uses Vaseline, poor girl uses lard. Baloffski uses nothing, he likes it nice and ….
  • Baloffski
    Baloffski
    3 years ago
    Steelo, you are a hard man.
