Online: FONTANA302
Putting together a 95" build need advice on cams
    4 years ago
    Adam you’re posting this repetitively here and in multiple yankee forums. From what I’ve seen you’ve been given heaps of advice and lots of good advice. Dunno if you’ll get much more here. Getting into it might be the go
  • Adam76
    Adam76
    4 years ago
    Quoting fatbat on 09 Mar 2021 03:21 AM
    Yeah, I've had lots of advice.  Some opinions contradicting each other. Just makes it more confusing.
    Just going to get started by pulling my motor down and starting with pinion shaft runout.
  • Adam76
    Adam76
    4 years ago
    Fat Bat.
    No offense mate, but your reply added no useful information, and I'm not "posting here repetitively". Are you keeping count? Did you not have nothing better to do at the time?
    Anyways, I'm at the critical edge of compression and camshaft choice at 200ccp with one of the build options I have and decided to see what others had done in their 95" / 98" builds here in Australia.
    Yes, plenty of info on US sites, but does not always relate or translate exactly. Different fuel, different headwork, different dyno tuners etc etc.
  • Adam76
    Adam76
    4 years ago
    Has anyone run the CR575 in a 95" - 98" build?  Intake close of 35* would allow me to use a lower compression piston and keep ccp at around 195.
    4 years ago
    Adam, inner cam bearings on 99-06 (99-05 on Dyna's) twin cams are .875". Inner cam bearings on '07 & up ('06 & up Dynas) twin cams are 1".
    Conversion cams have the .875 inner journal, and 1.00" outer; for using the newer style cam plate in older motors. Hope this helps more than my last post. Sorry mate, didn’t mean to sound negative. I just thought you had so much info you would be right into it. I tend to procrastinate and over think these types of things and need a push to get into it. Sorry mate
  • Adam76
    Adam76
    4 years ago
    No worries FatBat, all good mate 👍.
    I'm sticking with  the oem '02 Cam plate and pump at this stage. Don't really see the need to upgrade except maybe the Baisley spring and oil pressure valve mod. Depends on the state of the chains as well, if I have to replace worn chains then might consider a cam plate upgrade.
    And yes, sometimes too much information and too many opinions just makes things as clear as mud.  😂
  • John.R
    John.R
    4 years ago
    Would be keen to see what you end up with and what you're aiming for.
    I've got an 88 on the bench I'm about to get stuck into shortly. Have SE pistons and SE259 cams that where picked up for dirt cheap on the shelf that'll likely be used.
  • Adam76
    Adam76
    4 years ago
    Quoting John.R on 10 Mar 2021 10:40 AM
    Nice. Always good to have parts on the shelf and to use what you have.
    Are those the SE cast or forged pistons?
  • John.R
    John.R
    4 years ago
    Quoting Adam76 on 10 Mar 2021 11:06 AM
    Theyre the high compression cast set for 95in, however one of the pistons has a slight nick in on the skirt, so I need to chat to the bloke that does my cylinders to determine if they're even usable.
    Im leaning towards running them anyway.
    Need to pick a cam plate soon too.
  • Adam76
    Adam76
    4 years ago
    John, sounds like a good plan.
    Love the FXR in your galley, very nice build!
  • crowster69
    crowster69
    4 years ago
    Quoting Adam76 on 10 Mar 2021 08:06 AM
    speak to wes at cyclerama or the lads at alpha performance in qld who use cyclerama cams a lot if your interested in using the 575 cr cam.that cam can be used with stock compression but likes compression to 10.2 also.
  • John.R
    John.R
    4 years ago
    Any decisions yet Adam?
    Cam choices are currently doing my head in!
    The original/current plan is:
    10.25 pistons
    Se 257 cams
    96cu Heads.
    Now im worried it's going to too far in the top end and not pack enough mid too.
    What are you aiming for from the motor?
    4 years ago
    The SE257 will require some decent heads and around 10.8:1 to make it worthwhile.
    It will still be mid-top end power in a 95"
    I'm running the Andrews copy - TW67 ,  in a 120" .
    Totally different build in every way, but it has a decent amount of low end torque due to the extra capacity, and doesn't stop pulling .
  • John.R
    John.R
    4 years ago
    Heads will just be the later model ones whichare an improvement over the 88s, decked to bump up CR a bit.
    The whole thing does my head in, i wish I could just drop the whole lot off to a guru but there's  noone local.
    4 years ago
    If your set on stock heads I would avoid the SE257.
    Also if you are set on using the 10.25 pistons it limits Cam choices.
    There are a heap of different combinations I could throw at you that would work !
    An old favorite is Andrews TW54, - would bolt in with later heads - 10.25 pistons and no decking needed, comp'  set at 10.2 .
  • John.R
    John.R
    4 years ago
    Think I've landed on a setup and will be getting rid of the SE257. I like the idea of high HP, high RPM but realistically the bike will be used for wheelies and mucking around so probably needs a bit more torque in mid.
    The SE plate is looking like real good value too.
  • Adam76
    Adam76
    4 years ago
    Quoting John.R on 17 Mar 2021 11:12 AM
    10.25 pistons
    Se 257 cams
    96cu Heads.
    Not yet, I did pick up a set of brand new Cycle Rama CR575 chain drive cams that would go nicely with the Wiseco tracker 95" pistons and set me up at exactly 10-1. That's as far as I'm going until I pull the top end and see what's in the cam chest.
  • Adam76
    Adam76
    4 years ago
    I would also look at the Andrews tw54 or s&S 570. With 10.25 compression you should be in the sweet spot for both those cams which produce good power.
    I may end up selling the CR575 cams on if you are interested. They are a good HP and TQ cam, but could do with a set of better flowing heads. I have a set of 96" heads with less than 10km on them  (taken off a bike before it even left the dealership 11 years ago.
    If you do go with the SE cam plate I'm pretty sure you're limited too conversion cams only?
  • Adam76
    Adam76
    4 years ago
    Quoting crowster69 on 16 Mar 2021 02:37 AM
    Thanks crowster, only just read your post and I did actually speak to Wes at cycle Rama and ended up with a new set of cr575s.
    Not sure if I'll end up using them, but if I do I'm sure they'll go really well. 👍
    4 years ago
    Quoting Adam76 on 29 Mar 2021 09:51 AM
    So you changing your cam plate after all then?
