2002 Ultra Classic Check Engine light - ET Sensor Open/High?
  • UltraPete
    UltraPete
    4 years ago
    G'day All,
    I've had a check engine light occasionally flash for a couple of months now if I get on the throttle (I don't beat on the bike, but say I overtake or hit a steep hill 2 up), it normally goes away once I ease off the throttle. I was hoping to get it looked at next service (3000k away) Just come back from a run Avoca to Ararat and back, the last 20 mins the light was on solid (not flashing). Last I checked the flashes it was ET Sensor Open/High
    My nearest Stealership is Central Harley in Bendigo which is an hour and a half from me.
    Does anyone
    a. have experience with this fault?
    b. know a good indy mechanic close to Ballarat-Avoca area?
    c. think I should trade in for a newy? (haha)
    Thanks and stay safe
    Pete
    4 years ago
    Ultra Pete, when it comes on next, try stopping & turning motor off, wait a minute or too, then restart. if happens after restarting I would change or check the sensors. my twin cam carb I owned from new, used to do that, then one day it would not start & light just stayed on. I got a new crank position sensor & off she went no more trouble.
  • UltraPete
    UltraPete
    4 years ago
    Cheers KK, I've ordered a new engine temp sensor, will go over all the connectors when I change it out.
  • Lushy
    Lushy
    4 years ago
    Assuming the old two throat WM injection, is it engine temp or Inlet air temp?
  • UltraPete
    UltraPete
    4 years ago
    Quoting Lushy on 08 Mar 2021 03:54 AM
    Delphi EFI, Engine temp.
  • Lushy
    Lushy
    4 years ago
    Ok, early Delphi then. Check the wires to the eng temp sensor have not sagged onto/rubbed through etc the head, causing momentary shorting. It is worth a look.
  • UltraPete
    UltraPete
    4 years ago
    Quoting Lushy on 09 Mar 2021 11:33 PM
    Cheers Lushy, I'll do that!
