WTB rear one piece caliper
  • John.R
    John.R
    5 years ago
    Just incase you weren't aware, there are two calipers that look nearly identical but are slightly different. The one you have pictured is a Dyna caliper, but the Softail/Vrod/Tourer ones can look very similar.
  • John.R
    John.R
    5 years ago
    Quote source removed.
    The angle of the slot for the brake stay.
    Dynas brake stay its about 1.5in or so above the swingarm, parallel with the swingarm
    Vrod, Softy, Tourer is a brake stay welded to swingarm.
    What do you need the caliper for?
  • John.R
    John.R
    5 years ago
    Yep im with you, it wont matter what one you get than if you're removing that whole part of the caliper.
