Online: TNT
Mikuni 40mm versus 42mm
  • Benno
    Benno
    5 years ago
    Carby Gen guys, anybody got any opinions as to the argument of the 40mm variety versus the 42mm unit being better suited to a stock 1340. Excuse my ignorance.
    Benno
  • DocGreen
    DocGreen
    5 years ago
    Benno, my 2 cents worth - I fitted a 42mm Mikuni to my 94 Fatboy, slightly worked with SE heads, cam, Arlen Ness Big sucker a/c and a nice set of 2-1-2 pipes and honestly wished I fitted it earlier. Ran better everywhere, more responsive, butt dyno said I picked up a few hp.
    I persisted with the original carb, swapped jets, modified the slide etc and still wasn't totally happy, bolted on the Mikuni and happy days.
    I don't think a 42mm carb is too big for a standard or slightly modded evo 80". You could always swap jet sizes if too rich for a stock motor.
    DocGreen
    5 years ago
    if you are talking 40 vs 42 Mikuni ( and not 40mm CV ), you will find very little difference in performance at your level.
    The 42 has around 15cfm more flow, and is a more refined carb' , and would easily support ~115hp .
    If you have to buy one, go for the 42mm (future proof ), otherwise use what you have.
    A 40mm CV would also be perfect for a 1340 .
    5 years ago
    What I think is, if you have the factory cv40 on an EVO 80 inch & someone who knows how to tune the. CV, tunes to perfection.
    Then you get another EVO 80 inch same as first one. Put a Mikuni 42 on & tune that to perfection. Will be no difference. But if you race the two off the lights, the one with cv will jump away, provided both riders about same weight same skill . As you just can match constant velocity off the mark under load with a rider controlled throttle .   But if the two bikes side by side & rolling at same speed & both on the rev, then both open up full at same time . They would just Be even. If stock carb on just save your.  money.
    Only thing is Mikuni give detailed instruction how to tune the.   carb & not everyone knows how to tune a cv properly Bobby Woods has some different fuel curve needles & other parts to convert to Holley. main jets that increase in thou also you an  change the size of the air bleed. & few other things.
    but in the ends carb just adds fuel & air it is not some magic wand
    Good luck
  • Benno
    Benno
    5 years ago
    Thanks guys, I think I will leave the CV40 on for the moment and see if I can find someone that knows how to tune it, then see if I am happy with it.
    I want to leave it stock, but it's a bit pretty ordinary response wise.
    5 years ago
    Quoting Benno on 03 Feb 2021 01:55 AM
    Don’t let them drill the.  vacume hole in the slide to a different size leave hole stock size.
  • Benno
    Benno
    5 years ago
    Thanks for that Hoody, I really appreciate you taking the time to give me some backround on the Mikuni models. The 40mm Keihin CV that is on the Evo is stock 97 with stock manifold, both items look like they have never been removed.
    Could I ask if you know someone in Brisbane/SE Qld region that you would happy recommend for tuning the CV carb.
  • evo94
    evo94
    5 years ago
    same conclusion as Doc Green....
    years ago after farting around with CV for seemingly forever with modest results, i scored an old early model HSR42 (throttle linkages opposite side) off ebay for $40 sold as parts.....rebuilt it with kit from MikuniOz in Townsville (very helpful) & never looked back !
    as DC said "happy days"
  • Benno
    Benno
    5 years ago
    Roger that, thanks again.
