Online:
TNT
Fuel Coupling O-Ring Size?
Hound_Dog
5 years ago
Hey Guys, does anyone know the size of the upper O-Ring (the thick one) in the female side of the quick connect fuel coupling?
FONTANA302
5 years ago
Fuel Line Coupling O-Rings:
Large - ID 0.414" Thickness 0.072" OD 0.558" part #AS568A Dash Number 905
Small - ID 0.299" Thickness 0.103” OD 0.505" part #AS568A Dash Number 109
Go to any bearing/seal pace & quote the Dash Number. You will get them for cents in the dollar.
I buy mine from Sil Seal Innovations
https://www.sealinnovations.com.au/locations
Neale likes this post
Baloffski
5 years ago
Nothing but a Hound Dog............Dam good question and an enquirey for supplier of stuff rubber stuff..
But I get 404 man, so will try later.
F302 you have answered the question , I needed too , thanks.
Hound_Dog
5 years ago
Cheers guys. Get these Viton BS905 and Viton BS109. Suit all HD QD couplings.
Baloffski likes this post
DocGreen
5 years ago
Quoting FONTANA302 on 21 Jan 2021 07:33 AM
Good stuff Fontana302, you don't happen to know the oil drain plug o ring size do you?
DocGreen
FONTANA302
5 years ago
Sure do:
Soft Buna-N O-Ring ID 0.426" Thickness 0.070” OD 0.566"
#AS568A
Dash Number 013
DocGreen
5 years ago
Cheers mate
