Sportster Wont Start
  • Hound_Dog
    Hound_Dog
    5 years ago
    G'Day Guys, friend has a 2011 XL1200x that will fire but immediately (within a second or 2) dies. Trouble codes were PO373 and 374 Crank Position Sensor. Have changed this and still the same. Have replaced both O-Rings in the fuel coupling. Pump is running and seems to be pressurising fine. Any suggestions as to where else to look? Thanks in advance.
  • Hound_Dog
    Hound_Dog
    5 years ago
    Yeah mate, they are new, good spark. No problem there. Weird one this is.
    5 years ago
    Quoting Hound_Dog on 20 Jan 2021 01:18 AM
    No Good to read this!
    have you checked fuel filter & the fuel pump?
    Also what fuel is it running ? & how long since the last fill up?
  • Hound_Dog
    Hound_Dog
    5 years ago
    Quoting Krash Kinkade on 20 Jan 2021 03:28 AM
    Yeah mate drained the tank and new fuel. Bike apparently ran one minute then wouldn't restart. Pump is pressurising. I'm leaning towards ignition control module.
  • Uncle Chougs
    Uncle Chougs
    5 years ago
    Hey HD,
    Do you have some history about that bike before this happened?was it back firing etc...
    The symptoms might suggest a faulty coil.
    Is there good sparks? and what sparks plugs brand do you have fitted?
    What I would do is to check the spark plugs to see if they are wet or dry straight after trying to start the bike to check if we have a fuel problem or ignition problem...Let us know the outcome..
  • WideglidingNZ
    WideglidingNZ
    5 years ago
    so what fault codes is it throwing up now after you replaced the crank sensor?
  • Hound_Dog
    Hound_Dog
    5 years ago
    I always seem to get the combo deals. This bike came with leaking o ring at the QD. Fixed that, wouldnt start even with a spray of fuel in the TB. Checked codes got CPS so changed that. Wont start but does so with a spray. Remove fuel pump, line between pump and filter is split. Change that, runs perfectly.
