Online:
GGUser744, speedzter
Stage four kit on a 2015 break out
Far Canal
5 years ago
The good, your bike will have lots more power.
The bad, it will cost lots of money.
Breakouts are not renowned for taking corners too well either, a stage 4 kit might not help that.
Far Canal
5 years ago
Also what make you say it might not help with the cornering how would it make it any worse ..?
Well, you know, they (breakouts) don't go round corners that well bog standard. Going round the same corner plus an extra 30+ klm per hour will keep you on your toes.....or grind them off all-together on the bitumen.
Not trying to put you off. I had a stage 4 put on my bike (FXST) and have no regrets.
5 years ago
Are you for real? If you have the skill to "power skid " then you have the knowledge to know that a breakout with a stage 4 is not the bike do do it on.
Far Canal
5 years ago
This much.
https://www.youtube.com/watch?v=qmOv9SbCzKE
5 years ago
Oh god how do we attract these FB clowns...maybe a twin turbo sipping on a hit of NOS might get the tire lit up long enough to pop at 160kph and dump you on your head, hopefully that might knock some sense into your head. But i am not hopeful. Good luck with your build if you ever actually do one.
softfat likes this post
5 years ago
Quoting Far Canal on 15 Jan 2021 10:10 AM
This much.
Ha Ha....saw a few skids there...
