DIY Build a Lazy Susan/Turntable for Your Motorcycle (under $25)
5 years ago
Good trick rick k! As long as you are tall enough & have a low seat hight.
Also a good trick to know if, you don't like pushing bike back into a small shed or garage. when I first looked I though it was just a plank on piece of wood, looked a bit dicey.
Soapbox2627
5 years ago
To strengthen it up, you could frame the boards with angle iron and cross braces
I do the 5 point turn under my carport, couple seconds and it’s around, I did think about the build but looked at how much room I’d need as were would one park the bike after it was spun around
Krash Kinkade likes this post
5 years ago
would depend what your riding too, Dresser would weigh a lot more & need a stronger platform.
steelo
5 years ago
I'm pretty sure that for under $25, we could get access to some exotic aerospace grade unobtanium to build it out of.
rick k likes this post
gidgi
5 years ago
this is my attempt done bout 18 months ago for moving my Roadking about worked pretty good as well, dont have Roady any more so pulled apart
gidgi
5 years ago
Not necessary I just routed swivel rollers into the bottom of either end of planks, keeps it level & aids movability was a bit more than $25 I think the lazy susan was about that & was weighted to 400kg
