Charging a new battery.
Neale
5 years ago
Hi, swapped out my 4 yr old battery in my sportster for a newie today. Genuine MoCo part.
I’ve been caught out leaving it too long to replace a battery once before, don’t want a repeat.
My question is, is it normal to get a brand new supposedly fully charged battery and wait 6 hrs for my trickle charger to show it as being fully charged?
My charger is a 7 cycle you beaut job, not a cheapie.
The parts guy who served me said it was a good idea to do it even though the battery was good to go as is.
It seems odd, to me anyway..... 6 hrs.
Any comments appreciated.
Wideglider
5 years ago
Neale, your trickle charger will go through its whole you-beaut program & take time, 6 hours ok, if the battery was a little low, 80% or so. It would have been telling though if you had measured the voltage before charging, ideally should be no less than 12.5V before.
The old school ball-tearer chargers would have got it up to speed in 20 minutes though!
rick k and imoo6170 like this post
Soapbox2627
5 years ago
i can put the trickle charger in my bike as soon as I get home after a good ride and the light still indicated that it needs charging, never looked how long till green light comes on
Neale
5 years ago
Thanks.
FBUser42
5 years ago
In the battery factory i worked in we wet(filled] them then straight on charge.. Then dumped out the acid and refilled with a lower sg acid.. So your new battery yes when first filled will give you a initial start but will be low on charge.... You did it properly and your battery started life properly
Neale likes this post
steelo
5 years ago
You should be charged.
FBUser42
5 years ago
At my age they just say its another silly old c~nt
