SE Heavy Breather *Extreme* edition
  • Mesmer
    Mesmer
    5 years ago
    Happy New Year guys. Hope you all had a good one. Can I ask is there anyone on here running the Heavy Breather Extreme and if so did you notice any benefits afterwards? Thinking about putting one on my 114 Fat Bob.
    Many thanks
    Alan
    Edit: I should have said I already have the regular Heavy Breather + tuner and a TBR 2 into 1
  • Grease Monkey
    Grease Monkey
    5 years ago
    G'day mate, I don't run that particular filter but what I do know is if your current filter is a restriction on air flow then that one will cure it, if I could fit it on my 110 that's the way I would of gone, plenty of leg room and airflow, may need a tune up after depending on whether or not you current filter is holding it back, most likely not unless you have other mods, ie exhaust, headwork, bigger TB etc.
  • Grease Monkey
    Grease Monkey
    5 years ago
    Don't hate on me but maybe this is what you need.......
  • Mesmer
    Mesmer
    5 years ago
    Quoting Grease Monkey on 02 Jan 2021 06:34 AM
    128bhp!!! Oh my good Lawd!
    Lots of $s in that though?...
    Luverly :-)
  • Grease Monkey
    Grease Monkey
    5 years ago
    Bigfella did it to his, cam, gaskets, bearing, lifters and a tune, helps if you can do the spanner work yourself, he might see this and chime in on dollar's, not saying you should but I would because that's my hobby, messing with perfectly good motorcycles.
