Online:
Hilly
Effects of changing pipes has on an efi engine
FBUser42
5 years ago
Most back firing is caused by a slight air leak..the standard computer has a bit off vaibles built in. ]fuel quality. Altitude etc]
FBUser42
5 years ago
On my dyna i run power commander 3 so i can change my maps. If i do some mods i can update via my lap top..
FBUser42
5 years ago
Plenty off great guys here too help you . theres better units out there....my bike dosent run ozygen sensors. Pc3 does the adjusting. Automatically... Maybe some one else explain it better. As for fuel usage i dont monitor it. Care factor zero. Hhaa
rick k likes this post
Ratbob
5 years ago
As I guess you know
high flow exhausts like your Short Shots allow more fresh air to be pulled into the pipe, causing the exhaust temperature to rise and detonate any unburnt fuel.
I’ve not experimented with the Short Shots but done baffle mods with the Big Radius and both run the same style fluted baffle.
By inserting a screwdriver in each flute you can enlarge the opening which further interrupts the exhaust flow, problem is to get any noticeable change that will reduce the popping you need to cut the flutes and dramatically push them into the gas flow. Ultimately this fails as it makes the exhaust sound horibbly chuffy. I also extended the V&H baffle but it too failed.
I then built custom baffles with large deep flutes much like S&S mufflers but as the BR pipes are not a large diameter, the baffles could not be glassmat wrapped and again sounded horrid and would not stop the popping. Sure I could have made the baffles in a smaller diameter but there goes any performance benefit.
V&H make a quiet baffle for the Short Shot that might solve the popping but the only way to stay within the parameters of the original tune is to run original pipes.
Yeah your EFI runs variable parameters but has limits, exceeded by installing an open exhaust.
Custom
Extended
Flutes pushed in
Long baffle flutes in
dicko
5 years ago
from the factory your bike was tuned as close as possible to run STOIC about 14.6:1
The stoichiometric mixture for a gasoline engine is the ideal ratio of air to fuel that burns all fuel with no excess air. For gasoline fuel, the stoichiometric air–fuel mixture is about 14.7:1 i.e. for every one gram of fuel, 14.7 grams of air are required.
When you put your freer flowing intake and exhaust you cause the bike to run lean, and this causes "popping on decel"
Earlier bikes had a ECM with no oxygen sensors , and later ones have "narrow band sensors" meaning the range of adjustment is small or non existent.
The cure is a new map in both cases , or an aftermarket tuner ( such as thundermax with auto tune) which supply maps for different engine configurations, and has wide band sensors allowing the bike to readjust to stioc and thus reduce or eliminate the decel popping.
I have a thundermax for sale???
Ratbob
5 years ago
Gotta confess Ive never thought about fuel economy only reducing the noise of the big radius which failed so I switched to big radius 2 onto 1, much nicer.
The reality as indicated by Dicko is to get a proper tune. The Thundermax system is great but not cheap and you’ll need to learn how to operate it, not terribly difficult and it works. Then you can change the intake or exhaust as you like and retune it yourself.
5 years ago
I’ve had the big radius exhaust and played around with all types of baffles to no end. They’re a good looking pipe but very poor for performance. I had dyno charts to prove it. Baffling them gives a little more throttle response down low and quietens them a little (choking it at the top) but that’s about all.
Short shots are a worse pipe again. Too short, too open and obnoxiously loud. Factory headers with a decent pair of mufflers will run better. Even totally stock pipes may perform better.
Your bike’s gonna run lean too and that’s what the popping is. Baffling may richen it up slightly but it’s still likely to run lean until the tune is adjusted properly. Running an already hot air cooled engine lean isn’t good. I’d be inclined to spend extra dollars to have it tuned properly given the value of our bikes. Bike will run a lot better too.
Ratbob and rick k like this post
Ratbob
5 years ago
Yeah mate, live and learn, mostly that HD stands for
Hundreds of Dollars
5 years ago
At least short shots and big radius pipes are easy to sell and get your money back towards something better
Grease Monkey
5 years ago
You can keep your pipes, you have a powervision key now, that's part of what you paid the "tuner" fella for, you could get the bike dyno tuned by someone that knows what they are doing and have no popping, good fuel economy and it will run cooler to boot, I shit you not rick.
robots
5 years ago
So your poor fuel economy is from decel popping? 19kplL down to 14kpL amazing
softfat likes this post
robots
5 years ago
Looking better Rick K, spark plugs still a very good indication of how motor working.
You have a Powervision License Key, that allows SHOP to put a tune on your bike. That Key should be transferable so you can go to another shop if have too.
Give shop feedback and see if they can change the Tune a bit.
Often the decel pop is more noticeable with non-stock pipes.
Ratbob
5 years ago
Well yeah fuel economy will go down because the simplest way to stop the pop is add fuel.
Here's what one tuner reckons on the net
"For Delphi fuel injected bikes, we have found that adding fuel is needed to reduce popping."
So yeah, adding fuel to a point in the map where it would normally be zero, on decel (and where it's of no use in powering the bike) is simply wasted fuel but it's an easy fix.
Also you've fitted what are essentially drag pipes, not sure if you changed air intake, but one way to look at an engine is like a vacuum cleaner, the better it performs the harder it sucks and engines suck air and fuel.
I wouldn't blame the previous tuner, it might be subject to what you asked for. If you just asked them to stop the pop, they've done the right thing at least cost to you. If you specified that you wanted to stop the pop and maintain economy and lower end throttle response, most likely they would have considered the whole induction/exhaust/timing system and run a full Dyno and that's more $$$$ from you.
So yeah, as someone me, with far less experience I agree with Grease Monkey but also note that having had my bike tuned with a heavy breather and V&H exhaust 2 into 1, I'm still getting around 15kpl, but jeeze she goes.
Grease Monkey
5 years ago
Quoting Ratbob on 01 Jan 2021 01:05 AM
Just one last comment here, Ratbob a hang over from the early days is a rich cruise, dont need that now with so many tables at play in the calibrations, no reason for crap economy that isn't right wrist related, anyway I hope rick gets it sorted and is happy in the end.
rick k and Ratbob like this post
5 years ago
Fixing exhaust popping shouldn’t use so much fuel for the fix.
The TTS tuning module is as good a manual as you’ll find on tuning the Delphi harley ecu. Here’s what it says about exhaust popping.
“Exhaust Popping on Deceleration:
Exhaust popping on deceleration is due to a too lean or too rich mixture in the exhaust. This can be caused by a leaky gasket, or by the AFR being set incorrectly by the ECM. Most commonly, the mixture will be too lean. The ECM has three tables which affect this: Decel Enleanment, the AFR table, and the VE table.
The Decel Enleanment only acts for a short time (ie 1-2 seconds) after the throttle is closed. To richen the mixture during this time, decrease the value in the table at the temperature the problem occurs.
To richen or enlean the mixture during the entire decel event, change the AFR table in the in the first column (20 kPa between 1750 and 3500 RPM by 5 to 10 percent. Some experimentation here will find the sweet spot that eliminates the popping.
In the past, others recommended to change the VE table values to eliminate this popping. This will also work, however since changing the VE table has many other effects on engine operation, we do not recommended it.
Tip: To determine the MAP and RPM that is causing the popping, use the following procedure to "mark" the data recording.
Set-up DataMaster to record generic or O2 data
When you are riding and the popping occurs, pull in the clutch and let the engine revs drop to idle
When you play back the data, look for the idle spot at speed. The MAP and RPM that caused the popping are right before this.
Another way to mark a recording is to pull the clutch in and rev the motor twice quickly. Find a method that works best for your situation!”
And to clarify popping that comes in small multiples is a lean issue. One large pop/bang after a releasing a big handfull of throttle is a rich issue.
You only usually have to fine tune and adjust a very small amount of cells to address the problem if the fix isn’t resolved by the decel enleanment table on its own.
Reading plugs isn’t always helpful with fuel injection as you can be rich in some parts of your tune and lean in others. How are the plugs gonna show that unless it’s rich or lean all over the tune?
Grease Monkey likes this post
robnicko
5 years ago
https://www.youtube.com/watch?v=b3vn2NU3r1U
robots
5 years ago
This sounds very easy to fix.
Ride along, listen for pop, note rpm and then
adjust on computer. (2 tables!!).
Idle rpm is typically 1000-1100rpm. Can get familiar with rpm by watching in car.
5 years ago
Op, I just re-read one of your posts you replied to Dicko with:
“Dicko , it’s an earlier non oxygen sensor 2006 TC , oldie but a goody . It’s had a power vision dongle tune twice but not fixed the problem”.
Who did this? If it was paid work, take it back to them. A competent tuner should be able to easily resolve this. Even if not a dyno operator, they should still be able to easily resolve this if they have any idea of what they’re doing. If they don’t or won’t, they shouldn’t be charging money for what they’re doing
Even flash tunes provided over the internet from overseas (places like fuel moto who sell and support power vision, and Vance and Hines for their Fuel Pak) provide updated tunes to their customers to fix issues like this.
robots likes this post
Grease Monkey
5 years ago
You lucky, lushy is close by :)
robots
5 years ago
pretty easy to set up a cam to record the action
