Looks like new bars
Looks like new bars
Fartinfreddy
5 years ago
Been trying to decide between a new seat (ultimate or sundowner) or new bars /risers to get it set up a little better for me. This got me paying a bit more attention to my view which, looking at the fork cap bolts, it's gonna be new bars first cos these ones look to be bent. 😟
Fartinfreddy
5 years ago
The lower bolts on the clamps? Double checked and they're ok. Might be the angle of the picture. The bolt underneath that holds the riser in place was pretty loose on the left one but torqued up now.
Or is that the bolts you meant?
Fartinfreddy
5 years ago
The fact that the left hand bolt was loose enough that I could get some movement, along with rick k's comment made me wonder if the bushes were flogged out. Off to work for a couple of weeks but new bushes and 6" risers will be waiting when I get back.
Fartinfreddy
5 years ago
Thanks mate. I'll find out in a couple of weeks when I'm back.
