Online:
B0nes
Badlands Canbus Load equalizers
bodgie1307
5 years ago
Has anyone used these Badlands Canbus Load equalizers AFTER fitting aftermarket LEDS to front & rear to correct DTC codes ?
https://rolliesspeedshop.com/shop/lighting/turn-signals-associated/turn-signal-associated-parts/badlands-plug-n-play-canbus-load-equalizer-fits-rear-turn-signals-on-breakout-2012-2017-fls-2011-2017/
https://rolliesspeedshop.com/shop/lighting/turn-signals-associated/turn-signal-associated-parts/badlands-hard-wired-canbus-load-equalizer-fits-front-turn-signals-on-softail-2011up-dyna-2012up-all-h-d-2014up/
fitted both as per instructions and all lights plus dash indication works normal however the same DTC codes are still recorded.
DJP_120ci
5 years ago
Mine was an older dyna that was not canbus but I fitted a badlands unit after I installed the indicators and had issues.
I had to clear the fault codes. Have you cleared them and they come back? Or are they the same saved codes from before fitting the equalizer.
Hope that makes sense, cheers
bodgie1307
5 years ago
cleared and came back.
