Three phase stator wanted. Blown is OK
Nutty
5 years ago
I'm after the 3 pole plug that goes into the rec/reg.
Anyone have a blown stator hanging around?
AJ56
5 years ago
I have one ( Seal started to leaK so replaced it.) Do you want the whole thing or just the plug that goes to the Reg. It's off an 07 heritage. Change to that, I don't haver the plug. I had a look and they only sell the stator with the wires, I had to use the old plug from mine to fit to the new one. You might have to go to HD and order. FYI the part number for mine was 72614-01BK HOUSING, 4-WAY SOCKET (BLACK)
