Online: beaglebasher, Stuart
will a 4.5 gallon efi sportster tank fit on a dyna
  • FBUser10
    FBUser10
    5 years ago
    Has anyone fitted one of those non peanut style late model sportster tanks on a dyna frame (street bob 2007)
  • FBUser10
    FBUser10
    5 years ago
    Thinking more this look
  • Ratbob
    Ratbob
    5 years ago
    Quoting FBUser10 on 28 Nov 2020 03:51 AMedited: 28 Nov 2020 03:53 AM
    Fuzzy pic but to me it looks like a stock tank on a Shovel FXE.
    Of more interest to me as your fitting it to an EFI bike is how to manage the fueling (pump/filter) and electronics you’ll remove with the stock Street Bob tank.
    5 years ago
    Quoting Ratbob on 28 Nov 2020 07:26 AM
    I fitted that same tank to my Dyna carb model , I had a few old shovel FXE kick start only model. They are not a Sportster tank most are Shovel big twin tank, but they did haves roadster ( sportster ) model that used one, just the sportster that used that tank had the peacock on right side shovel big twin had it on left side.  Could use external electric fuel pump, the tank not hard to fit to a dyna , just all made for carb
    U can make anything fit anything if you want to. I think probably easier to look for an electric fuel pump that runs at same pressure. As factory EFI & mount on outside of tank
  • Mr.Mow
    Mr.Mow
    5 years ago
    Big problem with the dyna is the back bone of the frame is a horrible looking big square tube with a ton of wiring along it, the tanks cover a lot of nasties.
    Having said that I think easyriders Japan had a bolt on tank for Dynas but I don’t know if it was efi or carb
    5 years ago
    Quoting Mr.Mow on 29 Nov 2020 12:33 PM
    Mr Mow I fitted a shovel super glide kick start model [small battery model ] shovel tank to a twin cam dyna carb model no problem as that tank has a big wide tunnel for frime clearance
    I had two spare original tanks like that, sold on fitted other to dyna
  • FBUser10
    FBUser10
    5 years ago
    Thanks for then replies. I think I will go on a hunt for an old superglide tank and external fuel pump.
    5 years ago
    Quoting FBUser10 on 30 Nov 2020 01:34 PM
    what state are you in?
    If NSW I think I know where there is one, just not sure if would sell. pm me
  • Ratbob
    Ratbob
    5 years ago
    In line 12v fuel pumps are usually available from speed shops, try and get a small variable unit with a range at least between 55/62 psi (I think). Don’t wire it through the ignition switch but via the exiting wiring to the fuel pump thus keeping the EFI fuel cutoff relay intact.
