Online:
beaglebasher, Stuart
Deluxe Heat Shields
Deluxe Heat Shields
Daffy
5 years ago
Hi. Anybody got a couple of decent heat shields for a 2011 Deluxe. Preferably in SA. Think any Softail might be the same. Mine are dull and just getting a bit pedantic. Cheers
Spook
5 years ago
You have too much spare time, Daffy!
beaglebasher
5 years ago
Take them off and paint them black. Use high temperature paint.
The added bonus with this solution is your bike will look better than it did than before.
If you follow that advice you will need to use a lot of self discipline and not paint the rest of the bike
rick k likes this post
Daffy
5 years ago
Spook is correct. BUT NO BLACK!
