Online: John.R
RED security light stays on intermitantly after LEDS fitted 14 breakout
  • bodgie1307
    bodgie1307
    5 years ago
    Hi
    !4 breakout fitted with chopz option 5 ( integrated Leds) and baileys under perch front leds. All indicators / brake / tail lights work normally however the LH dash indicator flashes fast.
    Red security light stayed on until i used lh indicator .. bcm registered codes b2161 ( brake light open ouput ) , b1101 (lhcm bulb out). code b2161 cleared but b1101 will not clear.
    NO equalizer or resisters fitted.
    tried the 4 way hazzard sync
    tried the custom dynamics left & right indicator + 4 way hazzard sync
    code b1101 fails to clear
    anyone else had this ?
    Bodgie
  • bodgie1307
    bodgie1307
    5 years ago
    did the LED / BCM Sync as per harleys 4 way flash then cleared codes but B1101 would not clear.
    went for a ride all normal even the dash indicators and no red light. after ride re checked bcm codes and i have B2161 ( brake light open output ) B1101
    ( LHCM Bulb out ). cleared codes and this time both codes cleared. see what happens on next run.
  • Drac
    Drac
    5 years ago
    Also make sure all lights are working.
    I had a blown brake light bulb do the same thing
  • Grease Monkey
    Grease Monkey
    5 years ago
    I had to use an equaliser on my old Dyna but it wasn't canbus, still the blurb says for canbus so it must be a common issue and that's the remedy, mine was a badlands unit, fixed my problem.
  • bodgie1307
    bodgie1307
    5 years ago
    Fitted both units the plug and play for the rear and the hard wired for the front all lights work normal even the dash indication however the bcm still records the same codes B1101 ( left bulb blown ) & B2161 (brake light open ) .
    It does say in the instructions to fit modules BEFORE fitting non factory leds.
    ive emailed badlands for advice twice but have had zero response,
    Thinkin that cause i didnt fit modules before that they wont work. $200 wasted :(
