Online: Stuart
180 mm rear tyre
  • panz
    panz
    5 years ago
    Does any one know if you can go down to a 180 mm tyre on the rear from a 200mm tyre without changing the rim out, not getting a good run on the 200mm tyres even thou they look good the tyres wear out fairly quickly
  • Birtyyy
    Birtyyy
    5 years ago
    Shouldn't be an issue, just depends on what width the rim is.
