Online: Stuart
WG Rear Wheel - 5.5"
  • markmckenz
    markmckenz
    5 years ago
    Anyone got any suggestions for one of these in Perth so I can fit it to my FXDB?
    I purchased a 200 wide tire and the shop wont fit it to the standard Dyna wheel.
  • Birtyyy
    Birtyyy
    5 years ago
    So your standard rim is 17" x 4.5"? For a 200 wide tyre you really need a 5.5" or 6" wide rim. Might be able to buy a new rim and lace it to your existing hub instead of replacing the whole wheel. That's what I did.
  • Ratbob
    Ratbob
    5 years ago
    Quoting markmckenz on 02 Nov 2020 04:55 AM
    Why do you want to use a 200 tyre?
    I can’t think of any positives to it.
  • FBUser42
    FBUser42
    5 years ago
    Some guys will explain it better. But your dreaming. Unless the bike was designed for a 200 it will handle like shit [contact patch. Flicking side too side] .  the wider the tyre harder too ride.  But it looks kool riding to get a coffee at starbucks. Hhaa.
  • gidgi
    gidgi
    5 years ago
    I had an 07 FXDB with 180 on I think 5" solid rim & there was literally 6mm clearance to belt guard Doubt 200 will fit
  • markmckenz
    markmckenz
    5 years ago
    Just an FYI - The 200 is already on, but if I could find a rear the correct size it would be preferred.
