swimming Pool advise
  • bloodog
    bloodog
    5 years ago
    Way off topic I know but I'm a bit out of my comfort zone.
    Moved to Cairns 9 months ago and with the new house came a 50,000 litre pool
    The problem I have is the pool has a Dontek copper ionizer I have talked to 4 different pool shops and the verdict is, the system provides great water but tricky to maintain.
    Any of you lads live in the tropics and using my system ?
    I have just joined a pool forum but would be great to sort it with the HDF mob
    Cheers Bloodog
  • Soapbox2627
    Soapbox2627
    5 years ago
    my pool is only 25000lt with no ionizer, you have a good sand filter so I would run the system and manually test PH and chlorine at least once a week,
    does your pool shop charge to test water, ours gives a readout and instructions how to balance it back or maintain
    one tip, keep the pool stabaliser up, its "sunscreen" for your chlorine, stops it dropping out to quick
  • bloodog
    bloodog
    5 years ago
    Yer been taking water samples into pool shop
    I feel bad having them cheack the levels and then going to Bunnings to buy the products.
    Pool shops are almost double price
  • Benno
    Benno
    5 years ago
    Quoting Soapbox2627 on 01 Nov 2020 02:31 AM
    I reckon that stabilizer is just a money spinner for the pool shops, I used to use it all the time when I first got the pool (50 thou liter), cause they said "you need this", it's expensive shit in the doses they want you to use. I haven't put a drop of that shit in for 7 years, just run my chlorine up high and adjust how many hours a day it runs for depending on the temps at that time of year, never had a green pool ever.
    I wouldn't use that shit from Bunnings in my pool though BD, had a mate using the salt from bunnings and it stained the bottom of his pool cause of fine metal shavings in the salt.
  • wello
    wello
    5 years ago
    Quoting Benno on 02 Nov 2020 12:27 AMedited: 02 Nov 2020 12:39 AM
    yeh same mate .. pool shops piss me off .. always tell me i need about $200 worth of shit .. so now i just throw a couple of bags of sale in every now and then , plus some acid , and then a kg or 2 off chlorine and its crystal clear all the while now. and yeh that bunnings salt did the same to my pool as well so dont buy that shit.
  • Soapbox2627
    Soapbox2627
    5 years ago
    if you have a salt water pool, don't you have a chlorinator and make your own chlorine?
    I changed mine back to fresh water, I'll have to check but I think I threw it out last last clean out
  • Benno
    Benno
    5 years ago
    Quoting Soapbox2627 on 02 Nov 2020 01:07 AM
    Yeah Soapy, I have a saltwater pool, I add about 600ml of acid each week and have the chlorinator up near max in the summer for 7-8 hours a day.
    I only need to add salt maybe once or twice a year, usually after big rain, I wouldn't spend $200 a year on chems, for the pool.
  • bloodog
    bloodog
    5 years ago
    SB Its copper ionised filter and the lowest setting is 25 % I ran it at fifth % and dropped a pill in the filter basket every 2 weeks over winter
    This made the pool plate out / have an overload of copper 2.5 %. drained half the pool refilled and now just using liquid chlorine. I'm getting the hang of it, word is, copper ionised pools are hard to monitor in the tropics
  • Soapbox2627
    Soapbox2627
    5 years ago
    I turn my pool off over winter, I have a thermal cover and don't touch it until October, just started to clean out the "green" now because of our surgery, will take a couple days and vac to bottom
    I used to completely empty the pool and clean out 25mm of dirt the dogs would kick in and take 1 day to empty and clean, 1 day to fill and it would be ready to swim straight away, my water meter was also broken so cost nothing
  • Humbug
    Humbug
    5 years ago
    I know nothing about your copper ionizer as mine has a salt chlorinator ,but I do know not to touch any salt from bunnings or the larger grained salt as its dirty and as others have said will stain your pool. I have noticed that all the pool shops around here only sell salt from china,no one seems to stock any aussie salt.
  • Soapbox2627
    Soapbox2627
    5 years ago
    little insight for salt water pool owners
    I worked in a salt works many years ago ('82 2.5 years), swimming pool, course, fine, flossy, cooking and water softener salt are all the same only grind size and some have dust in them, Id buy the cheapest
    obviously, table salt has a free flow agent and iodine in iodized salt
  • bloodog
    bloodog
    5 years ago
    For fuck sale Bunnings salt must really be shit
    And its possibly the most easy ingrediant
  • Soapbox2627
    Soapbox2627
    5 years ago
    Quoting bloodog on 03 Nov 2020 03:26 AM
    remember guys, Bunnings don't pack it, with enough complaints, they can go back to the supplier/maker
