Online: GGUser744, Stuart
Installing Rocker Lockers
  • Phatty
    Phatty
    5 years ago
    Tomorrow's a public holiday and I'm gonna be pulling the Fatboy apart and install Rocker lockers in her.
    I ordered a set a few weeks ago but a few days later I thought I'll get a spare set incase.
    Price wasn't bad at about $65.00 a set delivered.
    I'll post some pics tomorrow and see how I go.
  • bloodog
    bloodog
    5 years ago
    Quoting Phatty on 04 Oct 2020 06:22 AM
    This is what I like about HDF
    Cheers PH
  • Grease Monkey
    Grease Monkey
    5 years ago
    If the shafts are slapping the bolts causing noise then they will cure it, thing is it might be something else but it does eliminate that problem, I use them, some think it's snake oil, if there are witness marks on your bolts and you fit them then that's one clack less.
  • Pagey
    Pagey
    5 years ago
    Snake oil or not they certainly helped quieting now my ride
  • Smokey61
    Smokey61
    5 years ago
    Where d'ya get 'em?
  • beaglebasher
    beaglebasher
    5 years ago
    What the fuck are rocker lockers?
  • Baloffski
    Baloffski
    5 years ago
    Good question BB.
    Many years ago there were certain types of persons whom asscociated with a partictular, err fold, for want of a better word.
    OK,
    there were the sharpies who rode a small wheeled thingos. Vespa was the common denominator, Sharpie was also aliggned with their hair style sorto weird and sharp.
    Next we had the Bikies, who rode mainly Pomie jazz , Triumph, BSA, Norton,AJS, and even Greeves, That many would not know what the fuck they were, plus some other stuff, AJS, Ariel, and so for forth. These dudes, were not to be fucked with, working in MC shop in early 70's was not uncommon to see a customer with a strapped pistol under arm, ex Viet vets, with a road to ride, they were cool. Then there weere the skeg heads, surfers. Pretty inococus crew unless ganged.
    I got on with all off them, when the shit hit fan, I was found to be a 16 year old under the pool table, till things quientened down at the certain pubs drank at, and would kick my 1971 XS1 Yamaha, and more than often carry someone home on the back. Arrh the olden days.
    Didnt answer ya question but a story, that was all good...
    I'm following Grease Monkey on this one though.
  • beaglebasher
    beaglebasher
    5 years ago
    That is a fukin great post . How are you keeping ski ?
  • Phatty
    Phatty
    5 years ago
    Well took it apart and had a look at the bolts and they had minor marks on them and the bolts were sloppy, The shafts were real tight.
    So went ahead and installed them , The bolts are a tight fit now no slop at all. The ticking I could hear is all gone now so they worked for my Fatboy.
    Here are some pics , If you do'em dont forget to change the O rings that come with the kit. I'm happy it got rid of the ticking and surprised how clean it was in there.
  • Phatty
    Phatty
    5 years ago
    Quoting Smokey61 on 05 Oct 2020 09:12 AM
    Where d'ya get 'em?
    Got'em sent over from the states.
  • beaglebasher
    beaglebasher
    5 years ago
    Some  nice  photography happening there.
  • Baloffski
    Baloffski
    5 years ago
    As BB said excellent shots guys, and forntose of us undersunder educated look, look up and learn.
     Thank you so much for imparting knowledge, is a valued more than money.. Ski
  • bloodog
    bloodog
    5 years ago
    David Attenborough would be proud of this post
    Thanks for that PH
  • steelo
    steelo
    5 years ago
    meh..
  • robnicko
    robnicko
    5 years ago
    i put em in my bike last year too.
    definitley quieter and they also make lining up the rocker assembly more accurate as well cause the slack is gone
    did you blow out the oil from the bolt holes before reassembly?
  • Phatty
    Phatty
    5 years ago
    Quoting robnicko on 06 Oct 2020 09:05 AMedited: 06 Oct 2020 09:07 AM
    Yes mate blew the oil out and soaked the bolts in Shellite to clean them up.
  • DJP_120ci
    DJP_120ci
    5 years ago
    Where d'ya get 'em?
    Quoting Phatty on 05 Oct 2020 12:48 PM
    Also available through Rollie’s locally now as well.
  • Phatty
    Phatty
    5 years ago
    Where d'ya get 'em?
    Quoting DJP_120ci on 06 Oct 2020 10:35 AM
    Yeah but they are wholesale only, You have to buy thru one of their authorised resellers in your local area.
  • Smokey61
    Smokey61
    5 years ago
    In Townsville that's Townsville Custom Cycles. Cheers for the info.
