Online: GGUser744, Stuart
shovel vibes
  • raybear
    raybear
    5 years ago
    By replacing the butterfly carb on a 84 shovel with a CV carb will it help reduce vibration at all .
  • Wideglider
    Wideglider
    5 years ago
    Ah, must be a trick question.
  • beaglebasher
    beaglebasher
    5 years ago
    yes of course it will.
    But the magnitude of the vibration  fluctuation of the butterfly valve might be too much for you handle if you are used to the old shovels
    Why do you ask?
  • raybear
    raybear
    5 years ago
    The original butterfly carb performs very well apart from annoying vibration over 85 ks , I have been given a good Keihin CV carb but would not waste my time fitting it if did not reduce vibration at all. The bike is a 84 FLHX so I wish to keep it visibly original as possible and to fit the CV I wont be able to retain the ham can air cleaner so I wish to be sure of eliminating some vibes for that sacrifice and I know I wont be able to get rid of all of them, Its a shovel so I have to suck up some vibration its the nature of the beast , Im just trying to tame it a little. I have installed a Dyna 2000 ignition but to no avail, Interesting though when I acquired the bike it was almost vibration free but the past owner had set the ignition advance timing well after TDC and I don't wish to put it back to that setting . Hope one of you guys out there can help
    5 years ago
    The Shovel's are mounted rigid to the frame, & don't have counter-balancers like say late softail .
    so you will always feel vibration, the CV carb if jetted right is great, as with the butterfly original carb they came with. you control about of air the motor gets, if you open too quick at lower rev the motor  might not respond as well till rev's go up, were with the CV your not controlling the air directly, the vacuum slide is, so motor will respond a bit quicker & smoother, but there will still be the same amount of vibration.
    bust there are a few tricks that could help cut vibration down, there is a product that you can bolt to the engine Sproket & another one that bolts to the clutch hub, they have built in weight that rotates and people reported they noticed less vibration ( I forget what they call the product but it is still out there. good luck & the CV carb is a good idea!
  • Smokey61
    Smokey61
    5 years ago
    Quoting raybear on 27 Sep 2020 11:07 AM
    No, not at all.
    On the carb though,
    I liked the old butterfly Keihin on my '86 Softy. Easyriders magazine had an article in '84-'85 on tweaking the Keihin, dunno it you'd get the bits now, but it cost me $27.50 back then for the jets and the older style higher volume accelerator pump. You had to epoxy up the hole in the bowl filling the pump, and drill out the passage to the old one (still part of the later casting). Align the pump jet to hit both cylinders, and as I live in the North and have no need for a choke, I removed the choke plate and shaft and sealed the holes. Issues were that the accelerator pump fitted to the later Keihin butterfly carbs was too small and refilled too slowly.
    Access to the idle adjustment screw was sealed from the factory too, but that was always sorted straight up by the dealer.
    There was a little more on thinning the throttle plate, shaft and screws, but I didn't bother going that far.
    Transformed the carb completely. Used to get a laugh walking into Rollies in Brissie and seeing a basket full of used ones for $5 each.
  • raybear
    raybear
    5 years ago
    Thanks krash and smokey , that's what I wanted to hear, the CV wont reduce vibes.  My butterfly is in very good condition at a genuine 20,000 mile and I get on well with it but Im sure the CV is a better carb and when I can do something about keeping the horrible ham can air cleaner I may install it at some stage , the backing plate collides with the vacuum chamber and a spacer will push the air cleaner out too far.  The last guys fix by retarding the ignition helped keep vibe down to a reasonable level but im sure that old shovel didn't agree.
  • liberator
    liberator
    5 years ago
    I bought new shovels back in the day, I still have a couple of 4 speed shovels, they cruise nicely at 90kph, I also have a couple of 5 speed shovels and they will cruise comfortably at 110kph, it's the nature of the beast,
    5 years ago
    Just check once in while everything tight, & they are not too bad.
    If something loose, especially top engine mount they vibrate a lot more.
    The 74 cubic inch shovel back in early 70’s was the smoothest I road, & pulled a bit better from down low. They had heavier flywheels & longer rods.
    CV carb just have to understand how to tune, The early cv40 did not have an excellerator pump, but the latter ones have them, I like the excerator pump.
    But in the end if what you have on it working fine & your happy, stick with it.
  • Wideglider
    Wideglider
    5 years ago
    Quoting Krash Kinkade on 29 Sep 2020 04:08 AM
    Even my Evo vibrates things loose, you get to know what to check after owning one for a few years. I carry a small bottle of medium-strength Loctite in my toolroll!
  • raybear
    raybear
    5 years ago
    your right far canal ill just have to suck them up, have used the bike for a while and it had very minimal vibes but I decided to put a Dyna2000 on because I felt the old ignition may become unreliable because of age and that's when I found that the ignition timing was set very retarded so I corrected it and presto I had vibrations , have moved the timing back and forth within spec but still vibes and Im not going to retard it to the stage it was originally set at  just to delete vibes. not nice for a good motor . I just wondered if a CV carb would help as I have one  but apparently not so will leave the butterfly on for now  as it works very well
    5 years ago
    Shovels look funny with cv,s on ,
