Online:
GGUser744, Stuart
Spark plug removal
Spark plug removal
Jamesstrathdee
5 years ago
Really embarrassing question but I’ve googled for weeks and purchased several slim sockets but I still can’t gay one thin enough to be wide enough to fit the plug?!
I’m sure there’s a rediculously obvious answer?
Far Canal
5 years ago
I'd be more worried about those push rod tubes.
Are you Joe Kenright?.
Jamesstrathdee
5 years ago
No? I’ve removed the covers and slid them down for access
Far Canal
5 years ago
Ok, fair enough. Right size spark plug tool must be available somewhere.
Even if you get one with the right size for the plug but too fat to fit in the outside, then grind it down so it works.
Jamesstrathdee
5 years ago
Thanks, yeah that was my next move, I was just wondering if I was missing some trick
Grease Monkey
5 years ago
I reckon you would have better luck with a tube spanner the right size, you know like what you use on lawn mowers or the like, just a thought anyway.
Jamesstrathdee
5 years ago
Great idea! I’ll grab some. I honestly thought this would be a really common issue
B.Zanetti
5 years ago
What engine is this?
5 years ago
Not a common issue as you don't come across dual plug heads very often !
Looks to be a 10mm plug, a jap bike plug socket should work.
Jamesstrathdee
5 years ago
It’s about 21mm 13/16.
It’s supposed to be an evolution engine in an 88 tour glide classic
