Idling problem
1/3
  • Smokey61
    Smokey61
    5 years ago
    Techs have failed, so putting it to the brains trust.
    The bike is a 2012 Wide Glide 103.
    Symptom 1./ When starting, sometimes the revs are up around 1500 for a few seconds before coming down to the normal 1000.
    Symptom 2./ This is intermittent, doesn't always happen. The bike runs fine for about half an hour, then starts idling around 1500 while on a trailing throttle or while coming to a stop, but returns to a normal idle when the wheels stop turning. The idle won't drop unless the wheels stop.
    Symptom 3./ Same as Symptom 2 except that when on a trailing throttle or coming to a stop, the revs drop to 500 - 600. Sometimes this continues when the wheel stops moving and I have to throttle up to keep it from dying, other times it recovers to a normal idle when the wheels stop.
    There are no stored error messages, no engine or electrical warning lights.
    The local shop had a go, couldn't find the problem.
    I've cleaned the IAC, and I'll be replacing the intake manifold seals and IAC today with new units.
    Anyone have any ideas before put it up for sale?
    5 years ago
    1.  This may be normal.  My 883 with a Thundermax does this each time.  Start her up and the revs go high for about 2-3 secs and then settles on the fast warm-up idle.
    2.  Replace the TPS sensor on the throttle body.  its cheap and take a couple of mins and can play havoc with idle when its on the way out.  The first 1/8th of throttle usage gets used a LOT on a harley and wears out.
  • robots
    robots
    5 years ago
    you have an intake leak
    follow the manual with new seals, the air cleaner backing plate has to be in position when the intake manifold is tighten up (centered/position on heads)
    Vaseline is best, also make sure sure manifold clamps are on the right way. Can be fiddly
    For peace of mind they can test wiring from IAC or other sensors back to ECM. If bike runs well outside of idle then everything else fine.
  • Grease Monkey
    Grease Monkey
    5 years ago
    Smokey if you want to see if it's an intake leak spray around the intake flanges etc while it's running at idle, if it flares up or stumbles it's leaking.
    The IAC can sometimes be clean but still not operate correctly so getting that out of the way would be my number 2 from checking for leaks.
    Hook up the dongle and check the TPS live if you get that far.
  • robots
    robots
    5 years ago
    IAC steps if you have PV (or other suitable device)
    speak to dealer about how the manifold is installed, it is crucial
    take the IAC out turn ignition on and on on handlebar and the IAC will cycle, nothing else can be wrong with it.
    I found that the wiring and sensors are very good quality, reliable and fault would be damage to wire.
    Had similar issue on my FXDWG, start fine, after 30mins or going for ride when you get back to idle situation (traffic lights, intersections etc) you notice the incorrect idle.   seals out of whack just a smidge
  • Grease Monkey
    Grease Monkey
    5 years ago
    Things can be clean and be worn out, what's inside the IAC one should ask, I'd near bet a nurry that's what it is but hey it's not in my shed.
  • Smokey61
    Smokey61
    5 years ago
    Ta for the replies, ran out of time today but I'll install new seals and IAC tomorrow.
  • steelo
    steelo
    5 years ago
    Good luck Smokey.
    Q. Why did the walrus go to the Tupperware party
    A. He was looking for a tight seal.
    Boom boom. Here every Monday. Try the veal.
  • robots
    robots
    5 years ago
    Good luck smokey, it might take a couple of goes with the intake seals.
    Make sure air cleaner backing plate is bolted to heads
  • Hound_Dog
    Hound_Dog
    5 years ago
    Hi mate, you dont have an IAC, you have a TMAP sensor. The guys are probably right with the air leak but you can also check the engine temperature sensor (screwed in the back of the front cylinder head), clean the crankshaft position sensor ( in front of the oil filter). You may have a fault with the TPS also. Had similar issues recently with my SG. Ask me why I prefer Shovels and Evo's!
  • Smokey61
    Smokey61
    5 years ago
    Quoting Hound_Dog on 22 Sep 2020 12:24 AM
    It has an IAC.
    5 years ago
    Just do not connect it up and power up the bike!  Chit flys off everywhere!  Dont ask me how I know...lol
  • Smokey61
    Smokey61
    5 years ago
    Can't remove the left side allen bolts in the manifold. I've removed top motor mount and horn for access but though some of my allen keys fit, I can't get enough room for a full 1/6 turn. Time for beer.
    5 years ago
    Quoting Smokey61 on 22 Sep 2020 05:27 AM
    you can get special made for the job, or make one you have fit.
  • Grease Monkey
    Grease Monkey
    5 years ago
    Quoting Smokey61 on 22 Sep 2020 02:33 AMedited: 22 Sep 2020 02:34 AM
    It has an IAC.
    It certainly does, the new one looks better :)
  • Grease Monkey
    Grease Monkey
    5 years ago
    Ball end key or the Harley tool, can cut a bit off the key, put it in the bolt, get a spanner on that, lots of ways to skin this cat.
  • beaglebasher
    beaglebasher
    5 years ago
    Quoting steelo on 21 Sep 2020 08:16 AM
    Good luck Smokey.
    I dont reckon you are taking this idling problem seriously steelo.
    And what the fuck is an IAC anyway?   I could hazard a guess but I dont want to appear stupid.
    OK,  I will take a shot.  Intake Air Control. ?
  • brucefxdl
    brucefxdl
    5 years ago
    Good luck Smokey.
    Quoting beaglebasher on 22 Sep 2020 09:02 AM
    so close BB, idle air control.
  • beaglebasher
    beaglebasher
    5 years ago
    Sounds like youve got the right attitude for this job Smokey.
    You dont want to be going in rip tear bust and fucking things up.
    As G M alluded to there are a few tricks to get the " CAPSCREW " out.
  • beaglebasher
    beaglebasher
    5 years ago
    Thanks for that bruce
1/3
