Online:
Stuart
Polyurethane Handlebar Riser Bushings - 56298-03A
Hog1
5 years ago
Hi
Fitting a new set of Factory47 bars on my SGS "18".
Having it all apart I thought to also up grading the Riser Bushings..
But little confused purchased HD kit..when I compare them with the stock ones.
Doesn't look right new kit bolt isnt long enough.
Am I supposed to cut down the actual bushing to make it fit?
You would thing it should bolt straight on.
Any help and input would be much appreciated......
DocGreen
5 years ago
Hog1, are all 4 halves of the bushing the same length? It's possible you were given the wrong bolts in the kit mate, had a look around but couldn't confirm what length the new bolts should be. I left my originals when I swapped out the bars on my 17 SGS to 12" WildI's.
I wouldn't cut the bushes, reuse your originals if keen to get the bike back on the road and see your dealer about the incorrect bolt length.
Good luck
DocGreen
Hog1
5 years ago
Hey DocGreen
Yes champ all 4 are identical in size.
No issue for bike to be back on the road..I would rather get it all 100% with the risers.
These are 12" aswell Assult i think there called..
Have another set on order should get them during the week to see if it was an error with packaging the parts..
5 years ago
In the meantime google that kit part number as the description should have the bolt lengths and/or harley part number in there.
