Online: GGUser744
2014/15 Breakout wheels on a 2020 Breakout
  • Mitchleeey
    Mitchleeey
    5 years ago
    G’day again,
    I’ve managed to hit a decent pothole resulting in a damaged rim, managed to stay upright. My old man has a brand new set of original rims for a 2014 Breakout. Will these fit my 2020 breakout or is there more work involved than what it’s worth?
    TIA!
  • wello
    wello
    5 years ago
    should be able to get that fixed
  • Mitchleeey
    Mitchleeey
    5 years ago
    Quoting wello on 16 Sep 2020 12:28 AM
    The rim?
  • wello
    wello
    5 years ago
    Quoting Mitchleeey on 16 Sep 2020 12:30 AM
    The rim?
    yeh .. lucily its bang on the spoke so i doubt its put it out of true .. just a matter of pressing side rim back into shape .. is it same on both sides ?
  • wello
    wello
    5 years ago
    maybe give these guys a call mate
    Two Wheel Wreckers / Two Wheel Service Centre
    2/30 Collingwood St, Osborne Park WA
  • Mitchleeey
    Mitchleeey
    5 years ago
    The rim?
    Quoting wello on 16 Sep 2020 12:38 AMedited: 16 Sep 2020 12:39 AM
    Cheers mate, I’ll call them.
    Just the RH side
  • Mitchleeey
    Mitchleeey
    5 years ago
    Quote source removed.
    Beauty! I’ll do some more research on getting it repaired. my local HD pointed me to a new wheel....
  • Ratbob
    Ratbob
    5 years ago
    From above O assume you’re in WA so there’s also Alliance Rim repairs.
    Probably just roll it out.
  • wello
    wello
    5 years ago
    Quoting Ratbob on 16 Sep 2020 01:27 AM
    i googled them and came up with a forum page .. didnt get to good a review for the amount they charge
    https://forum.perthstreetbikes.com/forum/motorcycle-topics/mods-being-technamikle-product-reviews/34866-alloy-wheel-repairs
    although it was quit an old post
  • micathia
    micathia
    5 years ago
    Quoting Mitchleeey on 16 Sep 2020 12:02 AM
    G’day again,
    TIA!
    I am very curious what kind of "hit" can do that?
    I rode into a pothole at 60kmh on a rainy day I felt my balls were squeezed hard. The bike (wide glide) has 80mm front wheel, the rim was ok.
  • beaglebasher
    beaglebasher
    5 years ago
    A mate of mine was following too close to the car in front and he saw something lying  on the road too late.
    It was a railway sleeper that had fell off a truck moments earlier. Fucked both wheels and both tyres.
    He managed to hang on but only just.
  • Far Canal
    Far Canal
    5 years ago
    G’day again,
    TIA!
    If I was me, I’d be looking for a straight front breakout wheel rim. Cunts write off those ill handling things all the time.See if you can buy a straight one first .
  • Jay-Dee
    Jay-Dee
    5 years ago
    G’day again,
    TIA!
    To answer your original question the early and later Breakout wheels are interchangeable. There are new Breakouts around with powdercoated and also chrome turbines and they're the same wheels as available for the previous model. I've also seen pictures of a couple of early models with the later wheels on them.
    I think you just need to get the correct wheel bearing kits for your model, check with your local dealer, they should be able to suss out the parts for you.
