s&s 625 cam
  • Nath103
    Nath103
    5 years ago
    Anyone running an S&S625 cam in their SG/RG?
    Bike goes in for build on Wednesday and Im leaning toward the 625 as it fits my riding style, however theres heaps of brands/options.
    Just wanted some first hand experience
    5 years ago
    Quoting Nath103 on 10 Aug 2020 03:19 AM
     I have run that cam, in a 95" TC SG worked ok.
  • Nath103
    Nath103
    5 years ago
    Yeah sweet.
    Im going 117 kit just wanted to make sure it had enough legs for what I intend to do
    5 years ago
    Quoting Nath103 on 13 Aug 2020 03:40 AM
    Yeah sweet.
    Should be perfect Nath.
  • jock 2013
    jock 2013
    5 years ago
    Hey Nath 103, be sure your compression ratio is above 10:1 or they wont work as good as they should. Ran 625g in my 117", dyno'd 126.4 HP, 125.37 TQ but still didn't seem to work as well as a 113 build i did with the same cams with 10.5 :1 pistons. Tried Woods tw400g-7 with impressive results, heaps of TQ starting about 1800 RPM but run out of legs on top end power & are noisy as. Going back to 625's and aiming for 10.5 - 10.7 compression ratio which my dyno bloke and I think will make a heap of differance to cam performance.
    5 years ago
    very good info!
    my 95 had a lot of comp , heads flowed well ( but have not got the flow numbers with me right now ). but for me the Andrews 55 G & a 1 1/2" spacer between manifold & carb , plus a bit more fuel, gave me the fastest speeds in quarter mile & quickest time. but was just 95"
  • Nath103
    Nath103
    5 years ago
    Fingers crossed I get the bike back tomorrow. Then the run in stage. Not 100% sure if the build will have 625 cam as I left that option open for the builder to crunch numbers with 10:5 comp and work out what will give best tq from 2700-5500rpm.
  • Nath103
    Nath103
    5 years ago
    Got my bike back. Currently in run in phase with rev limiter set at 4500.
    Runs strong even being detuned for the short term.
    Sitting about 60/60 hp/tq and it pulls like a train, hoping to see minimum 130 hp/tq once its all run in and dynoed correctly.
    Overall main build compnents are:
    117 cyc
    89cc heads
    58mm TB
    S&S 635cam, oil pump and all that jazz
    TTP variable clutch
    5 years ago
    Quoting Nath103 on 03 Oct 2020 10:39 PM
    117 cyc
    89cc heads
    58mm TB
    TTP variable clutch
    Any update....
  • Far Canal
    Far Canal
    5 years ago
    117 cyc
    89cc heads
    58mm TB
    TTP variable clutch
    Quoting paulybronco on 03 Nov 2020 07:16 AM
    Any update....
    Word has it QLD state of origin team are all getting that cam fitted tonight.
    5 years ago
    117 cyc
    89cc heads
    58mm TB
    TTP variable clutch
    Any update....
    Quoting Far Canal on 03 Nov 2020 08:42 AM
    HaHa think its a bit like my std Street Glide trying to outdrag a top fuel dragster....Qld to go down in a close one. NSW to win by 1-12 points
  • Nath103
    Nath103
    5 years ago
    Final tweeks late next week.
    I still need to put on a few hundred km but the cold wet weather mixed with arthritis smashed me. I did fit new wheel and tyres yesterday. Trying the Bridgestone k50s Need to scrub them in for weekend ride up the coast
  • Nath103
    Nath103
    5 years ago
    Scrub in was going well until axle shifted forward and belt had too much slack and saw me pull over on the side of the M7 on way home from Wollongong.
    Brother came with tools and 2 second fix to get it home. Closer inspection and so forth Ive been given the wrong spacer kit from HD so need to have a word to them about that and sort it out today
  • steelo
    steelo
    5 years ago
    Thanks for info speedzter.
  • Nath103
    Nath103
    5 years ago
    Bikes back on deck.
    134hp 120tq.
    The TBR exhaust is hurting the TQ and drops off a bit before the cam rolls on at 3500rpm, so needless to say Ill be selling a 2000km old TBR turnout exhaust once I work out what full length 2:1 system Im going to run.
    Also got another surprise coming in the week or too
    5 years ago
    Quoting Nath103 on 18 Nov 2020 01:38 AM
    Bikes back on deck.
    134hp 120tq.
    Hey 120tq aint a wimpy effort......most 2-1 have a breath before they start pushing hard
  • Wideglider
    Wideglider
    5 years ago
    My question has always been - why don't the tyre manufacturers remove this silicone based release agent? Surely in this age of risk management laws it should be the case. Guys new to bikes sometimes are not made aware of the need to scrub in new tyres.
  • John.R
    John.R
    5 years ago
    There is no silicon based release agent, it's the biggest myth and misconception out there. I think it may have been used a few decades ago?
    Even scrubbing in tyres, people over think it. I can have a brand new set of tyres, ride out to the Twisties (20kms away) and have it knee down, 52/54* lean angles with no dramas.
