Online: Soapbox2627
Front wheel lock for Wide Glide 80mm/21" front tyre
  • micathia
    micathia
    5 years ago
    anyone (wide glide owner) can recommend a product for it? that works on 80mm/21" tyre?
  • micathia
    micathia
    5 years ago
    bump!
    wheel lock I mean this:
    It says work for 21" wheels but doesn't say if 80mm is ok.
  • blueystar
    blueystar
    5 years ago
    WHEEL CHOCK
  • STEAMER
    STEAMER
    5 years ago
    Tjey are all multi adjustable  i have fxst, has
    21 x 90/90 wheel  fits good. I have also used on an Wideglide &  Heritage & Ultra.
  • micathia
    micathia
    5 years ago
    cool thx.
  • steelo
    steelo
    5 years ago
    I like the way you've got your trailer set up Steamer. Is there a panel that goes in the gap for normal use
  • STEAMER
    STEAMER
    5 years ago
    Quoting steelo on 12 Aug 2020 03:35 AM
    Yes Steelo,  when not using for bikes. The part i cut out, was riveted to some alloy chequer plate and bolts in to use as normal trailer.
  • Airhead
    Airhead
    5 years ago
    Quoting STEAMER on 12 Aug 2020 10:03 AM
    Excellent, I am inspired to copy the design.  Have been trying to sort the best way forward with a bike trailer for years.  I already have the six by four.
