Online:
Soapbox2627
Bloody Rattle in the exhaust
5 years ago
So, Getting the FXR ready for an inspection for club plates and needed to quieten down the pipes. Easy, just buy the baffles and insert!
So... The baffles are not wide enough so needed to add a ring to make them fit all good. Then test road last week. and ALL I can hear is a bloody rattle rattle all the time. Crap I think i need to wedge the front of the baffle to cut down the noise so pull out the baffle and give the pipes a good knock... MOST ODD its still rattleing!
15mins of head scratching later I wonder if there is something up the pipe...
THAT explains why I was a bolt short for my Door Bolt I build the other week...lol.... I do not want to even ponder how the fark that happened.!
